Can I ask - what are the best connectors for limit switches and steppers these days?
Surely not still DB9 :)
I should say this is for connection into a custom-built case to hold the driver electronics, PSUs etc...
Alan
17-06-2021 #2
17-06-2021 #3
"Best" is such a funny word. DB9 are cheap and cheerful, but I doubt many think they're best at anything. Possibly not ideal for steppers, though if only an amp or so, shouldn't be too bad, but solder-bucket type (rather than crimp) are likely to fracture over time. A lot of us use the GX16s or GX20s for steppers. Question is - what's your environment - if not damp (e.g. coolant, etc) then you don't need anything too exotic. Really useful, in a paradoxical sort of way if you can e.g. swap stepper axis over (i.e. like-connectors without unique keying) - for quickly checking motors/drivers when you have problems, arguably similar for limit switches. My own strategy at this time - 4-pin XLR for steppers (high current capacity, very cheap from CPC/Farnell) and DB9 for signalling (just because you can get 3M 1-1 cables made up for peanuts).
17-06-2021 #4
The best connector by far is NO connector, wire them direct to drives and controller. Every connector is a potential trouble area, If only I could get back the time for every bad solder joint or terminal I've chased I'd be 10yrs younger and still have a full head of hair.
So if you really don't need them my advice is don't use them and save some money and a lot of time.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
17-06-2021 #5
18-06-2021 #6
Thanks guys, in that case, I think I'm going to use the GX 'Aviation Connectors' for this one. Probably for both steppers & limits.
Ta, Alan
Proximity switches or limit switches
By chillybo in forum Gantry/Router Machines & BuildingReplies: 52Last Post: 29-06-2021, 11:50 AM -
What Limit Switches?
By Chaz in forum General ElectronicsReplies: 26Last Post: 14-12-2016, 10:50 AM -
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Limit Switches
By Leadhead in forum General ElectronicsReplies: 1Last Post: 16-10-2013, 10:41 AM -
Limit Switches
By Lee Roberts in forum General ElectronicsReplies: 13Last Post: 27-06-2008, 02:21 AM
