Thread: Axis sticking
06-06-2021 #11
Daz you took the words from my mind.
To the OP with 28V voltage, you are playing Russian roulette and you will blow those drives if you try to run at high feeds and deaccelerate quickly as the steppers turn into dynamos and dump 40v + back into the drives.! . . . . . . Careful with the regulator as well because if it shuts down with the back EMF you'll get hassles.
My advice is to buy decent drives and throw those toys away and run the higher voltage, it will transform the machine.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Test Dial indicator sticking?
By Neil C in forum Workshop & EquipmentReplies: 3Last Post: 03-04-2019, 04:33 PM -
B Axis indexing and easy workflow for repetitive cuts 4-axis
By deemoss in forum General DiscussionReplies: 1Last Post: 21-06-2017, 12:34 PM -
Not cutting perfect right angles and sticking on Y axis ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 10-12-2012, 09:41 PM -
XYZ Centurian 450 VMC tools sticking during tool change (M06)
By craftydonkey in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 19-10-2011, 03:11 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
