Thread: Newbie Novice
To be fair while the machines are very capable of doing this, in reality, you wouldn't really cut that aggressively to be fair, but the point of the comment wasn't for bragging rights to how good my machines are it was to make the point that a properly built machine is much more capable.
I understand what you think your needs are at this moment in time are simple, but experience has shown me and many others on here will probably agree that when the CNC bug bites you will quickly want to do more advanced projects and it's at this point you start to realize the weaknesses of these low-end kits and electronics/software. Nothing more frustrating than wrecking materials and tools along with wasting many hours because the machine just can't handle the job.
Now obviously, can see I'm wasting my time trying to steer you in the right direction and away from these weaker machines and kits, you also seem to be ignoring the advice to do research to learn what does what and why it's required. So all that's left to be said is good luck.!!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
15-06-2021 #2
Now obviously, can see I'm wasting my time trying to steer you in the right direction and away from these weaker machines and kits, you also seem to be ignoring the advice to do research to learn what does what and why it's required. So all that's left to be said is good luck.!![/QUOTE]
Thank you Jazzcnc - your the engineer - I am not even an apprentice
However, i have neither the funds nor the time to spend on a top machine and I am having to sell off some older woodworking equipment to fund my build.
I cut a 22mm MR MDF sheet last night to 1000 x 1000, allowing 100mm around perimeter of the base (100mm base, top and either side) with an 800x800 centre box area for the machine. That's not a big machine at all from what i have seen.
Where do i get decent plates from? Unless i make them from 18mm birch ply?
Do i get my C Beam from Oozenest?
Best place to get the motors and Nema 23's any good?
Ball screws & rails, best place to buy?
NEW MEMBER: Another CNC Novice
By andyisko in forum New Member IntroductionsReplies: 7Last Post: 28-03-2019, 10:35 PM -
NEW MEMBER: Big hello from a total novice
By Edendale in forum New Member IntroductionsReplies: 1Last Post: 29-01-2018, 11:03 PM -
NEW MEMBER: Heres me - a Total Novice
By CrazeUK in forum New Member IntroductionsReplies: 1Last Post: 14-03-2017, 03:47 AM -
NEW MEMBER: Novice after some advice
By lukenotts in forum New Member IntroductionsReplies: 4Last Post: 06-03-2013, 09:52 AM -
NEW MEMBER: Novice from Liverpool
By John51 in forum New Member IntroductionsReplies: 1Last Post: 28-10-2010, 11:23 AM
