Thread: Newbie Novice
You may be in for a shock then.Any program will require an amount of input to function.They may be located in all sorts of places,but they all need similar information regarding cutter geometry and feed speeds.The most basic letter carving program I have used is F-engrave and you need to supply tool geometry and feed rates.
15-06-2021 #2
Thanks routerdriver, ironically, you put in your cutter dimensions, intended depth of cut, router type etc and it works out all the feed rate etc. It even shows you if use different sizes of cutters what it will miss out on the final carve because the bit is too big etc
16-06-2021 #3
Do you honestly think it's that easy.? IF you do then you are in cuckoo land.
No software and I mean NO software, not even software costing £10k+ can work out the correct feed rates and spindle speeds as there are far too many variables involved.
The best they can do is offer speeds and feeds based on tool parameters just like a speed and feeds calculator does, these are notoriously way off most of the time because they are based on industrial machines and spindles.
Anyone who has used one will tell you at best they are a guide which you use and tweak based on your own machine's strengths and weaknesses. At worst they are miles off and you'll just snap cutters like carrots if you follow their suggestions.
Speeds n feeds is a whole learning curve in its self and each machine, cutter, and material combination will change the settings. This is why what works for one person often doesn't work for others as there are just too many variables that come into play.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: Another CNC Novice
By andyisko in forum New Member IntroductionsReplies: 7Last Post: 28-03-2019, 10:35 PM -
NEW MEMBER: Big hello from a total novice
By Edendale in forum New Member IntroductionsReplies: 1Last Post: 29-01-2018, 11:03 PM -
NEW MEMBER: Heres me - a Total Novice
By CrazeUK in forum New Member IntroductionsReplies: 1Last Post: 14-03-2017, 03:47 AM -
NEW MEMBER: Novice after some advice
By lukenotts in forum New Member IntroductionsReplies: 4Last Post: 06-03-2013, 09:52 AM -
NEW MEMBER: Novice from Liverpool
By John51 in forum New Member IntroductionsReplies: 1Last Post: 28-10-2010, 11:23 AM
