  1. #5
    Quote Originally Posted by bambuko View Post
    And as for pre-loading the bearing - it is internal in the double row bearing so I don't need to (and couldn't) do anything about it. Ijust need to secure the bearing in place.
    Not pre-loading, just loading. As drawn it resists a push but not a pull.
    If the double race is tight in the housing you could put a sleeve down inside so when you nutted the pulley on the top you pinched the double angular inner ring.
    That'd do it.
    Edit: I do have experience, here is a double angular bearing loctited on a spindle from my junk box
  1. WANTED: Small milling head
    By johnsattuk in forum Items Wanted
    Last Post: 14-03-2014, 08:54 PM
  2. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  3. NEW MEMBER: In over my head
    By Tele45 in forum New Member Introductions
    Last Post: 03-01-2014, 02:30 PM
  4. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  5. diy Engraving head
    By riche543 in forum Metalwork Project Showcase
    Last Post: 25-06-2012, 01:31 PM
