    Muzzer, try to understand something. I bought this 4th axis rotary chuck and it comes with a belt giving 1:6 reduction. It is NOT something which is a choice, the belt is a necessary thing in it, not an "expensive reduction gear" which I design. In fact, direct driving would be impossible because there is a hole through the rear, so unless you want to give that up, you MUST have a belt or some sort of arrangement to drive the chuck. Besides, if we take your own torque chart as example and my actual 1:6 gearing then you can see that at 2280rpm that motor should have approximately 10 oz-in (units make no difference in the calculation). Now because of the gearing, the torque is 6 x 10 = 60oz-in but the rpm is down to 380. So, yes, while the torque is not that much bigger, but still bigger, and is definitely 6 times the value read from the chart. Not much is gained compared to direct drive at low rpm, but never the less, there is a gain, even with your motor chart. I have also said that the gearing is mostly a help between zero and very low rpm, I am aware of that, but still, there is no way you can directly drive this chuck, except through putting in a 1:1 belt, but that would mean I lose even holding torque, which is the very reason these belt ratios are used the first place.
    Now, to make something clear, this is the motor I am considering: https://www.jmc-motor.com/product/980.html
    It says: "Nema 23 Integrated AC servo motor 180W" ...and it is not a printing error, because I am sure it is the same as any other AC servo, except that the driver is fed using maximum 50VDC, so the rectifier is outside the driver, as I said before. The motor has a 0.6Nm (85 oz-in) torque all the way to 3000rpm with a max torque of 1.5Nm. Now, by using the same 1:6 belt I'd get 3.6Nm holding torque AND all the way to my current maximum chuck speed, which is 380rpm. In other words, I gain at the speedy end, but lose on holding torque, since my current steppers have 1.8Nm x 6 = 10.8Nm, but my current stepper has 0.5Nm at 1500rpm, which is quite a bit from 2280rpm (my current speed). I have no torque table above 1500rpm. My guess is that the torque is very low at that high speed. With the servo I could go to 3000 rpm (or even more), so that would definitely be beneficial for the rotation, but not for holding torque.
    Yes, I know that combining a 4th axis and use it as a lathe is not a good idea according to a professional, but to me, this is just for fun, I don't aim at competing with anyone except myself. I aim at getting experience, knowledge, having fun, enjoying my time, exercise a hobby and so on.
    Correct me if I am wrong, but don't say that I "happy to redefine terminology", because I am not. I did not make any calculations before, but definitely not redefined anything and torque is definitely increasing when you add a reduction gear. I think you understand that very well, but if you don't understand what I am saying that's a different thing, and is perfectly possible that I am not that clear, but that does not justify such statement. I am not stupid, I can read charts, make calculations (in ANY sort of units) and so on. You are not the only one with engineering background and long and prosperous career.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Erm..you did though -
    I think the only difference between AC and DC servo is that an AC servo driver has the rectifier built into the driver, while a DC servo must be fed using an external DC PSU with a rectifier circuit in the PSU. When I say DC servo, I mean just that the driver needs DC current, but it is still a servo, and NOT a closed loop stepper.
    How any given motor controller gets powered, does not define the type of motor attached to said controller.
    An AC motor doesn't suddenly become a DC motor because the controller needs DC power.
  1. FOR SALE: Lichuan 4.5Nm Closed loop stepper systems
    By JAZZCNC in forum Items For Sale
    Last Post: 29-07-2021, 05:48 PM
  2. Closed loop stepper motor encoder help
    By DenJon in forum Gantry/Router Machines & Building
    Last Post: 23-04-2020, 04:55 AM
  3. Closed loop stepper motor kit power supply
    By the great waldo in forum Motor Drivers & Controllers
    Last Post: 21-09-2019, 10:08 AM
  4. Testing Leadshine closed loop stepper system.
    By JAZZCNC in forum Stepper & Servo Motors
    Last Post: 13-10-2012, 05:39 PM
  5. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:11 AM
