16-06-2021 #11
I don't mean stepper, but servo.
Yes, but my problem is space, so I would like to avoid larger motors. All AC servos I have seen take up a lot of space, and even though the PSU is just a simple transformer, it does need a large one and that takes space, unless it is driven directly from the mains. At this stage, I'll avoid both for now. If need arise, I may change my view, or like I said before, buy a real lathe, which functionally will most probably be better than what I can build. To be honest, I think it would be more point in upgrading a real lathe with a large AC servo then doing it in my DIY "poor man's lathe" which will probably end up being pretty expensive in the end, I know that, but I want to try, learn and improve incrementally. I know that such approach costs money, but for me it is more fun this way. Starting a huge project to build a perfect and powerful lathe takes a long time and I don't think I have the patience to do that. Also, I am just an amateur "machinist", don't have any real need for this except as a hobby, so I am not at this stage interested in starting a huge project which will never be finished.
I feel that this hobby is like a black hole, it can swallow everything, including ones family life, fortune, space and time, so I must set some sort of realistic limit to my ambitions. I am well aware that this, once ready, will be far away from perfect, but that's OK for me, even if some parts will in the end not be used, or replaced shortly after a test.
Right now, I am aiming at some DC servos, but I think before that decision is made, I will build the X and Z out of real parts, which for me will be based on some HGR20 and HGR15 linear rails plus 1605 ball screws.
FOR SALE: Lichuan 4.5Nm Closed loop stepper systems
By JAZZCNC in forum Items For SaleReplies: 9Last Post: 29-07-2021, 05:48 PM -
Closed loop stepper motor encoder help
By DenJon in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-04-2020, 04:55 AM -
Closed loop stepper motor kit power supply
By the great waldo in forum Motor Drivers & ControllersReplies: 19Last Post: 21-09-2019, 10:08 AM -
Testing Leadshine closed loop stepper system.
By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM
