Looks identical to this kit: https://www.aliexpress.com/item/1005...%2315609%23247
Recently I bought a similar kit, but not from the same seller. https://www.aliexpress.com/item/1005...47344c4dvbomq4 I only needed 400mm long, and I must say that what I received is excellent, I am very happy with it.
I try to avoid sellers with such low rate as 94%, but your stuff can be equally good as mine. 1000mm is pretty long, so it is more critical, but otherwise I think it should be fine. Mine are good quality. Kitwin is a bit negative... unless there is a manufacturing defect, to say that they are "better than the skate bearing and angle-iron alternative" is really nonsense. Of course they are better, even supported round bars are better, MUCH better. You can't compare with those under the same sun.
That said, you should be prepared to clean the bearings. They can come dirty from the factory, but cleaning those linear slides is really no big deal. Generally, I think that good cleaning is always necessary, though these last ones I bought seems very nice and clean. All my bearings came individually packed, nice in sealed plastic bags, as well as all the other things, everything individually packed. I don't know if yours will be the same.Last edited by A_Camera; 16-06-2021 at 01:34 PM.
17-06-2021 #2
That was my point, even the lowest quality rails of this design are going to be way ahead of any cheap, DIY construction that other builders turn to in order to save money. And I certainly hope supported round rails are better as well, that's what I'm using! Though If I'd seen these rails at that price when I built my machine I may well have chosen them instead.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
17-06-2021 #3
I am glad that I misunderstood your comment before.
Same here. Been using those for several years now, initially planned to replace them one day, but gave up the idea because I think they are just fine for my needs. My first CNC was based on unsupported round rods, and while they worked, and even could earn some money using them, I decided to upgrade to supported round rails. The results were satisfying and now, while it would be cool to have these HGR20 rails with HGH20C bearings, I think the work it demands to make the change is not worth it. Yes, these rails are fairly cheap today, but unfortunately it is not a "plug and play" work, but demands a serious modification of every axis. Maybe if something seriously goes wrong with the machine I'll do this as well as fixing the serious issue, but for now I'll be fine.
Yes, I'd definitely chosen these rails if they were as cheap as they are today. As I remember, these were a lot more expensive back in 2013 when I started with mine, and at that time I wasn't even sure that I really wanted a CNC. I just built one for my own mental challenge, to see if I can design, build and learn how to use one, so spending that much on something so totally "useless" thing was just not what I wanted to do. Today it's different. For all newly starters there is a gold mine out there, because really, we have to admit that those cheap Chinese things got a lot better in quality during the last years, so buying cheap is not necessarily the same as buying crap.
Xzero Raptor CNC build - linear rail and ballscrew selection
By Mattia in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 27-08-2021, 01:34 PM -
2m+ travel lengths with a ballscrew, using linear rail to support the ballnut
By Desertboy in forum Rails, Guideways & BearingsReplies: 9Last Post: 04-02-2018, 06:50 PM -
3 axis ballscrew and rail kits on ebay
By Richard in forum Classified Ads, Buy, Sell & SwapReplies: 9Last Post: 18-05-2017, 02:06 PM -
NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
By yvesleeok in forum New Member IntroductionsReplies: 11Last Post: 10-08-2013, 11:15 AM -
Linear rail and ballscrew dimensioning for R/C router
By CarlNicholasCarlsson in forum Linear & Rotary MotionReplies: 0Last Post: 24-03-2013, 06:52 PM
