22-05-2021 #1
Hello All
Has anyone used one of the JMC iHSV57-30-18-36-21-38 180watt servo motors on a Z axis ball screw (with a standard 2.2kw spindle motor) or similar without a brake fitted. I was wondering if the weight of the spindle motor would be enough to turn the ball screw and drop the motor down to the work table and cause damage to any bits in the spindle collet when the system is powered down?
AndrewLast edited by the great waldo; 22-05-2021 at 07:37 PM.
Motors - To Brake or Not to Brake?
By BigBrand in forum Stepper & Servo MotorsReplies: 3Last Post: 14-02-2021, 12:52 PM -
4th axis brake enquiry
By marbles in forum Linear & Rotary MotionReplies: 17Last Post: 12-05-2020, 09:02 AM -
DIY 4th Axis with Brake - The Build
By koenigsegg in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 03-02-2020, 07:39 PM -
correct wiring sizes for JMC Servo iHSV57-30-18-36-21 with axbb-e controller
By the great waldo in forum General ElectronicsReplies: 18Last Post: 31-01-2020, 11:58 PM -
lathe dc servo motor brake/spindle lock ??
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 01-11-2014, 05:22 PM
