    When setting the machine limits, the only way I know to reset the z axis to zero is to press 'ref all home' which sets everything to zero.
    The problem is that when I switch the machine off the z axis drops a bit so the next time I switch on I dont want to have to reference everything again. So how do I only set the y axis for machine limits (not workpiece offset)?
    ZASto's Avatar
    Lives in Belgrade, Serbia. Last Activity: 11 Hours Ago Has been a member for 5-6 years. Has a total post count of 49. Received thanks 1 times, giving thanks to others 1 times.
    At every powering on the machine should be homed. Period.
    Suppose you have micro stepping drives and when your machine is stopped at the end of your day, motors are at "some" micro step position.
    When you switch power off, motors will spring to the nearest FULL step position, defined by the magnets in the motor.
    As drivers are not intelligent enough (read: dumb), they will at power on be at the full step position, and the result is, you may guess :) : unreferrenced machine.
    Lazynes for clicking at one button after power up?
    Quote Originally Posted by ZASto View Post
    The problem is his machine doesn't have any HOME or Limit switches so he can't send HOME.
    Quote Originally Posted by grantx View Post
    Grant, without HOME switches you cannot get around this problem. Like ZASto mentions if the machine had HOME switches fitted you would and should HOME each axis when starting up or after every E-stop for the reasons ZASto stated above.
    When you are pushing REF ALL HOME now what you are actually doing is setting MACHINE coordinates to ZERO, because you don't have any switches on the machine the DRO's just change to ZERO's but if you had switches fit then when push REF ALL HOME each axis would move towards the Switch on each axis then ZERO the DRO's.
    Also, with HOME switches you will always be able to accurately find WORK ZERO again if something goes wrong or you have to E-STOP.
    At the moment you have issues you don't even know you have and HOME switches will partly help with this.?
    Because the Y-axis uses 2 ball screws you have no way of knowing if the gantry is square, so HOME switches will allow you to set the gantry square.
    However, worse than this and highly likely to happen on your machine is if one motor stalls and the other keeps moving the gantry will twist up, this can very easily bend the ball screws if it happens at higher feeds, which is often the case because torque is lowest at higher rpm's.
    Now, HOME switches won't help with this but they will allow you to straighten out any twist in the gantry after it happens.
    To deal with handling the stalling motor requires extra wiring in the control panel and feeding signals back to Mach3. If the machine was built properly this should have been done but as you know it's not so you'll have to do this and I FULLY recommend you do it sooner rather than later because it will happen at some point without a shadow of a doubt.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Hi Dean. That is concerning. What must I do to prevent a stalled motor from twisting the gantry? I will do whatever needs doing to avoid that from happening.
    It depends if the drives have a fault signal.? If they do then you can use this to control a relay that puts the control box into an E-stop and reset condition then signals to Mach3 there's been an issue so it can stop the G-code. But again your machine is so poorly wired regards Safety that to do this properly will virtually require a rewire of the control box.
    If the drives don't have a fault signal then you are a bit stuffed without getting deep into using encoders etc and cross-checking with the other axis.
    Ok so in my case the drives don't have fault signal outputs. I am going to have to think outside the box then. Im not willing to just leave this.
    There must be another system that is separate to the drives and controllers that monitors the position of each side of the gantry relative to a fixed position. If they go out of alignment then the entire system disables.
    If the left side of the gantry has a distance from the edge of Xmm then the right side must have the same distance. If at any point either position moves out of tolerance (lets say tolerance of 2mm each way) then emergency shut down.
    What could I use to monitor this? Any ideas?
    Doddy's Avatar
    Not what you want to hear - but almost certainly better to replace steppers with closed-loop.
    You *could* attach rotary encoders onto each screw and - not sure of any COTS solution - knock up an encoder comparator to generate a fault signal. Rotary encoders are in the £10-£20 range for cheap, and an Arduino is the cheapest way to implement the comparator. But that's all a little bit of a bodge.
  8. The Following User Says Thank You to Doddy For This Useful Post:
  1. The 2DM860H chinese controllers vs the rest?
    By Nr1madman in forum Motor Drivers & Controllers
    Last Post: 23-04-2020, 12:25 PM
  2. Windows 10, is it better than the rest?
    By magicniner in forum Computer Software
    Last Post: 28-11-2019, 11:04 AM
  3. CNC Project - Guitar Neck (and the rest if I can get away with it)
    By Washout in forum Woodworking Project Showcase
    Last Post: 28-01-2018, 10:45 AM
  4. Foot Rest Project and how I did nesting in Fusion 360
    Last Post: 24-09-2016, 11:57 AM
  5. NEW MEMBER: Back after a little rest
    By bogstandard in forum New Member Introductions
    Last Post: 27-02-2015, 07:12 PM
