Thread: OpenBuilds Style Build
01-07-2021 #21
Thanks A Camera
The profiles that virtually everyone on OpenBuilds is using is this - https://ooznest.co.uk/product/c-beam...l-cut-to-size/
A lot of guys in the US purchase from them in the UK.
Never used a drawing for anything i have made.
I measure the dimensions of what i want to make and where it is going to go and then just get on with making it.
So, i need to make a bookcase for an alcove -
Height, width, depth, height of books from large to small, thickness of material being used, allow for rebates etc - all just written down as physical sizes. No drawings
I look at other designs, profile edges, create radius corners, all based on what i think looks aesthetically pleasing!
I will make use of most of what i have - but the ball screws are to short and will cause an issue as they are the exact length of all my profiles.
Were as the others are oversized generally by 40mm or greater to allow them to pass through the plates and be secured.
WoodKnotCarpe Diem
01-07-2021 #22
Ok first off I wasn't having a pop at you or trying to discourage you with negative comments. Most of what I said was and nearly always is said for the sake of others who are thinking to build and reading this. It saddens me that I have to do this and use you as an example of "How not to do it" and I know with 100% certainty, because been here many times before, that if you had done more research and made at least minimal drawings this wouldn't have happened.
Regards learning CAD then how do you think you are going to create parts to cut without even basic CAD.?
These things would have happened on those kits as well, they just don't tell you these trivial details.
Ok well nobody's giving up on my watch.! . . .So if we can't make a stubborn bugger listen then I will just have to help him get it sorted out and working..
You probably won't need to scrap the ball screws and I'm sure we can make something to extended them if your only 40mm short, you may lose 40mm travel but won't cost you anything.
However, before we or I can help you further will need to give me a detailed list of what you have and the length and dimensions. Either post it here or drop me an email and I'll help you get this together. YOU ARE NOT GIVING UP..
Email: [email protected]
Web site: www.jazzcnc.co.uk
01-07-2021 #23
Who said anything about making parts Jazz - Just pretty little signs!!! Things that sell at craft fairs and the like - if i decide to go down that route?
Yeah - thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I think we are both clearly in the same but opposite camp there
OK, open to suggestions - i did have an idea!! an outer plate and an inner plate - how the bloody hell i was going to make them though?
All my extrusions are exactly 1000mm
All my linear rails are exactly 1000mm
All my ball screws are exactly 1000mm
You kind of see my problem - i can understand how the 'linear and ball screw kit worked - but it was never for my profile of extrusions!!
To be fair (as I like to say!) why would i not assume that the ball screws would be longer, they are when you buy them separately
Oh, just to make you smile, laugh or cry? Why did no one tell me that if you take the nut off the ball screw, that all the bearings fall out! What a crap design
WoodKnotCarpe Diem
01-07-2021 #24
Ralph Waldo Emerson
01-07-2021 #25
Parts, pretty little Signs, or great big honking signs, call them whatever you like they all have to start with lines and arc's so you can generate the G-code in CAM. How do you think you are going to generate the files for cutting if you are not going to use Cad or some Vector drawing software, which is basically a kind of Cad.?
01-07-2021 #26
Oh, I see. Well, those extrusions are in my opinion far too weak. I was hoping that you at least use 40x80, but those you went for, I see as 20x20 C shaped. Maybe suitable for some very small, light machine with a small DC motor as spindle, but not for a machine of the size and type of use you are aiming at, even if you'd only work with soft wood, I think that would cause you more pain than joy when using it. I think at this stage I'd byte the bullet and start over, trying to reuse the strongest parts (rails and ball screws), not the weakest ones (extrusions), but in any case, I think it's high time to start sketching on paper or in a computer.
Also regarding CAD, I think you must give up any idea about not wanting to use one. I understand that you don't want to spend a small fortune on a CAD software, but there are very capable and useful software out there even for free. FreeCAD is what I am using and as the name says, it's free of charge, unless you are like me and want to donate money to those developers. There are other free CAD and CAD related software out there, and if you are aiming at ever using your CNC then you simply must learn some CAD software, without that, you will have really no use for a CNC. Even a simple freeware like F-engrave needs some understanding and configuration, as well as the CNC software (whichever you plan to use) needs some serious configuration, input file with some G-code containing the correct setup for the material and the cutters, spindle motor and many, many things. It all sounds simple and looks as a simple work, but it isn't. You can, if you are good at low level programming (like I am), create G-code without CAD/CAM, or any other software, using only Windows Notepad, but it takes time and requires a good understanding of G-code, but it is not practical and it takes time, especially if you are not a professional programmer or have many years of experience and knowledge. I started with manual G-code programming and actually created fairly complex items because I was in a hurry and for me it was easier and better this way, while I was trying to find my choice of CAD which I'd be happy with, but I have over 40 years of experience in programming, of which 15 in assembly and C, and the rest is C++, Ada, Ada+ and so on, so with my background it was the right choice, but if I did not have that background, I would have never started with manually programming in G-code. So, while I still stand for what I said, machines can be designed without CAD software, I strongly recommend you to seriously consider some CAD software because you will need it.
Here is a video about FreeCAD and Blender, the guy uses FreeCAD (just like I do) for designing parts and he assembles those parts using Blender, which is also free. I think that this is a very good idea, so I actually installed Blender and will have a look at it for myself.
I am also not interested in spending a fortune on CAD/CAM and modelling software, but of course, those who work professionally and actually selling machines, these are necessary tools, and commercial ones are expensive for us mortals, so for me the free alternatives are suitable. As I said, FreeCAD is free, but donating is fine, you can actually donate any sum and to be honest, it is a professional software, so those guys and dolls deserve my money every time I update the software. I just installed Blender and that is also freeware (donate ware) and a quick test shows that I like it, but will test more and if I ever use it for real I will donate them as well, just like I donate other software makers. But it is not compulsory, and those software don't have any limitations if you don't donate, so that's good. Many commercial alternatives have free versions, but every time I tried one, I run into limitations, so I gave up on them because even they claim that you get the full version, they are ALWAYS cripple ware, or have some serious limitations in usage time, saving possibilities, maximum sizes or other things which can be frustrating or make life difficult.
In short, you should start consider some sort of CAD and accept the steep uphill it may cause before you get started for real with one.
01-07-2021 #27
We need more details.
What profile are the extrusions?
What size are the rails? 20mm?
What size are the ball screws, what type of ball nut is fitted, and what support bearings are fitted?
Either links to what you've bought, or some photos will help us provide suggestions.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
01-07-2021 #28
I actually don't see the problem with those lengths. With those lengths you can indeed get the full length movement, which is 1000 - 160 = 840mm. There is no such rule that screws must me longer than the rails. As I said before, it depends on the design, but you always lose at least as much as the carriages take (normally more) so why would there be a problem? The 1605 should be machined like this:
Attachment 30161
So from the full 1000mm you lose 11 + 39 + 15 = 65mm which means that you have 935mm movement and that is more than enough for your 1000mm rails. ...but you can't build that on a single 80mm wide extrusion, so you have to come up with a better solution. Anyway, we need more details, MUCH more details.
If you absolutely want longer screws, one solution is to cut off a bit of the rails. The length is easy to shorten, just use an angle grinder. But like I said, it isn't necessary to have longer screws at all.
I think by the way that I indeed mentioned NOT to remove the nut, and be careful when installing the carriages because the balls will fall out. But... if that happened, you could collect them all, clean everything and assemble all together again. It may take time, but no big deal. I think you can even buy balls only, in case you have lost some. Here is an example of a seller:
https://www.aliexpress.com/item/1005001533634944.html but DONīT buy any without you checked carefully the size and know if you really need some. Note that I have nothing to do with this seller and never had to buy any yet.Last edited by A_Camera; 01-07-2021 at 06:31 PM.
01-07-2021 #29
01-07-2021 #30
OK, I have read everything that has been said so far!
All the machines that I have seen, watched, use this profile, on wheels, no rails, many belt driven and they knock out some nice stuff.
I know that you have all said they flex, so how are they managing it. Many make 1500mm x 1000mm machines from this stuff!
I thought by putting some HGR 20 linear rails on, that would introduce a lot more rigidity into the build
Most of the upgrades that people are doing is that, but often using 12mm rails and occasionally 15mm rails.
Most are still using 8mm Acme ball screws, I went for Rm1605, so twice the thickness.
Yes, I have seen the issues with long 8mm screws 1500mm long, I believe you call it whip or something else?
So I have exactly 40mm to play with between the rails, less the HGR20 carriages.
WoodKnotCarpe Diem
There are currently 42 users browsing this thread. (0 members and 42 guests)
OpenBuilds C-Beam machine
By Lodds in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 25-10-2020, 04:39 PM -
Will the openbuilds ox cut aluminium?
By davejavu123 in forum OpenBuilds OX CNC MachineReplies: 5Last Post: 19-05-2019, 07:12 PM -
Turret style cylindrical cnc grinder build
By SGG70 in forum Other Machines & BuildingReplies: 3Last Post: 19-12-2018, 02:00 AM -
SOLD: Openbuilds 3D CNC Router for sale
By Leadhead in forum Items For SaleReplies: 0Last Post: 15-12-2018, 09:30 AM -
Anyone have info on OX CNC made by Probiotix openbuilds
By totally useless in forum OpenBuilds OX CNC MachineReplies: 11Last Post: 16-06-2015, 02:16 PM
