Page 7 of 7 FirstFirst ... 567
    The three phase you have at work and different industries is not the same. These spindle motors can not be connected to an ordinary 3-phase plug, you must use an inverter. However, to run the inverter you don't necessarily need three phase, my VFD uses one phase, but it internally converts to three. Regarding guidance on electrical installation, I prefer not to. All I can say is that it is my personal opinion that the offer you have from Jazz for all that is a bargain, even if it sounds expensive in your ears. You can probably buy the parts cheaper individually, but you save a lot of time and trouble if you buy everything soldered and ready to be plugged into a wall socket.
    BUT... before you say yes to the offer from Jazz, you MUST have your design ready, not just assume that everything fits together and works well. I mean, the whole machine MUST be ready for assembly, at least on paper, because that spindle is heavy, so you can't use small and weak steppers. You have already made an expensive mistake, don't continue the same route. I am sure that the delivered good from Jazz would work, but can your gantry handle everything? Have you decided for the type of design? Have you decided for the CNC software and the interface to your PC? Will it be Linux or Windows driven? Have you made any considerations of the electronics? Can you design and install everything, connect and solder all the wires and all that's needed to do? How large is the Z and what will be the Z clearance from the table top up? There are so many things to think about, so if you have not done it already, it is time to lift a pen and take notes in a booklet called "My CNC Design" or something similar.
    Sorry A Camera, I have got inside help ��
    Carpe Diem
    Hi A Camera -
    I am Microsoft and an Android fan - so Windows - software will be Easel - Controller is BLACKBOX, no soldering (although i have purchased a kit)
    Motors are Nema 23's 285oz
    Should be alright
    Carpe Diem
    Giood morning Jazz
    Please don't commit any more time to it please.
    I need a bit of time now to consider my options.
    Let me know what I owe you for your time please
    WoodKnot
    Carpe Diem
    Quote Originally Posted by WoodKnot View Post
    Giood morning Jazz
    WoodKnot
    Don't owe me anything and I would be more than happy to continue if you wanted, however, my honest opinion would be to start again with new profiles like 45x90 and re-use the rails and bearings rather than trying to make everything fit those profiles.
    Just let me know if you want to proceed further.
    Lastly, to make you aware the motors and electrics you have bought are also less than ideal so at some point, if you continue, expect to be upgrading these or if want to do it right from the start sell them and buy decent stuff.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Yes, thanks Jazz
    Big decision time now - not sure at the moment which way to go................
    As in, try to sell what does not work (most of it) and start from scratch, but be prepared to probably lose at least 30%
    Or ditch the whole project and start again at some other point in time?
    The plates that you have come up with are great, but agree that they 'don't look right' due to my mismatch of purchases.
    Such is life
    WoodKnot
    Carpe Diem
    Ok, let's start again, bad idea?
    So, by using 3 of the 2040 profiles to create the required space?
    WoodKnot
    Carpe Diem
    Attachment 30237
    Attachment 30238
    WoodKnot
    Can't see them.?
    Good evening Jazz
    Posted and deleted, stupid idea!
    WoodKnot
ID:	30235   Click image for larger version.
    Carpe Diem
    Hi All,
    Been having a go with Sketchup 2017 - seems very intuitive and easy to use, far easier than FreeCad -
    But with everything, there maybe downsides?
    Your thoughts would be appreciated
    WoodKnot
    Carpe Diem
    Good evening Jazz
    Good that you are very busy!
    3 x C Beam 4080 all 1000mm
    5 x 2040 all 1000mm
    1 x 4080 at 300mm
    I can always get more if it helps
    WoodKnot
    Carpe Diem
  1. OpenBuilds C-Beam machine
    By Lodds in forum Gantry/Router Machines & Building
    Last Post: 25-10-2020, 04:39 PM
  2. Will the openbuilds ox cut aluminium?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 19-05-2019, 07:12 PM
  3. Turret style cylindrical cnc grinder build
    By SGG70 in forum Other Machines & Building
    Last Post: 19-12-2018, 02:00 AM
  4. SOLD: Openbuilds 3D CNC Router for sale
    By Leadhead in forum Items For Sale
    Last Post: 15-12-2018, 09:30 AM
  5. Anyone have info on OX CNC made by Probiotix openbuilds
    By totally useless in forum OpenBuilds OX CNC Machine
    Last Post: 16-06-2015, 02:16 PM
