Thread: OpenBuilds Style Build
07-07-2021 #18
Definitely too fast for some aluminium, but it's not just about RPM, it is also about the cutters you use, the diameter of them, the cutting speed (feed rate) and also the material. Not all aluminium is the same, and there are different plastics also.
As said, that may depend on many things, but most likely is the speed rate being too low, or the cutter is the wrong sort. I have had issues with some acrylic which melted on the cutter all the time, but eventually, I managed. It must however be difficult using a manual router because you don't really know the feed rate and can't really keep it constant. As soon as you slow down a bit too much, some plastics and aluminium melts and glues onto the cutter. Some times it helps if you spray with water, but I don't normally do that.
OpenBuilds C-Beam machine
By Lodds in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 25-10-2020, 04:39 PM -
Will the openbuilds ox cut aluminium?
By davejavu123 in forum OpenBuilds OX CNC MachineReplies: 5Last Post: 19-05-2019, 07:12 PM -
Turret style cylindrical cnc grinder build
By SGG70 in forum Other Machines & BuildingReplies: 3Last Post: 19-12-2018, 02:00 AM -
SOLD: Openbuilds 3D CNC Router for sale
By Leadhead in forum Items For SaleReplies: 0Last Post: 15-12-2018, 09:30 AM -
Anyone have info on OX CNC made by Probiotix openbuilds
By totally useless in forum OpenBuilds OX CNC MachineReplies: 11Last Post: 16-06-2015, 02:16 PM
