Thread: OpenBuilds Style Build
07-07-2021 #13
You don't need a Water-cooled spindle but they are SOOOOOOOO much better than a standard router, with far less noise, stronger power, continuous duty cycle.
I sell them as a Kit only, this includes 2.2Kw ER20 Spindle, Huanyang VFD, 1 to 13mm Collet set, Spindle mount, water pump with the pipe. £265 + postage.
You will also need a shielded CY cable from VFD to Spindle which we can supply at £1mtr cut to length and will solder the VFD connector on free of charge.
You don't need any special wiring in the workshop and they will plug straight into a 13A supply if required. Occasionally, if you have a sensitive MCB in your Fuse box you may need to change the type from B to C MCB but this tends to happen mostly in very new properties and not very often.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
OpenBuilds C-Beam machine
By Lodds in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 25-10-2020, 04:39 PM -
Will the openbuilds ox cut aluminium?
By davejavu123 in forum OpenBuilds OX CNC MachineReplies: 5Last Post: 19-05-2019, 07:12 PM -
Turret style cylindrical cnc grinder build
By SGG70 in forum Other Machines & BuildingReplies: 3Last Post: 19-12-2018, 02:00 AM -
SOLD: Openbuilds 3D CNC Router for sale
By Leadhead in forum Items For SaleReplies: 0Last Post: 15-12-2018, 09:30 AM -
Anyone have info on OX CNC made by Probiotix openbuilds
By totally useless in forum OpenBuilds OX CNC MachineReplies: 11Last Post: 16-06-2015, 02:16 PM
