Thread: OpenBuilds Style Build
The three phase you have at work and different industries is not the same. These spindle motors can not be connected to an ordinary 3-phase plug, you must use an inverter. However, to run the inverter you don't necessarily need three phase, my VFD uses one phase, but it internally converts to three. Regarding guidance on electrical installation, I prefer not to. All I can say is that it is my personal opinion that the offer you have from Jazz for all that is a bargain, even if it sounds expensive in your ears. You can probably buy the parts cheaper individually, but you save a lot of time and trouble if you buy everything soldered and ready to be plugged into a wall socket.
BUT... before you say yes to the offer from Jazz, you MUST have your design ready, not just assume that everything fits together and works well. I mean, the whole machine MUST be ready for assembly, at least on paper, because that spindle is heavy, so you can't use small and weak steppers. You have already made an expensive mistake, don't continue the same route. I am sure that the delivered good from Jazz would work, but can your gantry handle everything? Have you decided for the type of design? Have you decided for the CNC software and the interface to your PC? Will it be Linux or Windows driven? Have you made any considerations of the electronics? Can you design and install everything, connect and solder all the wires and all that's needed to do? How large is the Z and what will be the Z clearance from the table top up? There are so many things to think about, so if you have not done it already, it is time to lift a pen and take notes in a booklet called "My CNC Design" or something similar.
07-07-2021 #2
08-07-2021 #3
OpenBuilds C-Beam machine
By Lodds in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 25-10-2020, 04:39 PM -
Will the openbuilds ox cut aluminium?
By davejavu123 in forum OpenBuilds OX CNC MachineReplies: 5Last Post: 19-05-2019, 07:12 PM -
Turret style cylindrical cnc grinder build
By SGG70 in forum Other Machines & BuildingReplies: 3Last Post: 19-12-2018, 02:00 AM -
SOLD: Openbuilds 3D CNC Router for sale
By Leadhead in forum Items For SaleReplies: 0Last Post: 15-12-2018, 09:30 AM -
Anyone have info on OX CNC made by Probiotix openbuilds
By totally useless in forum OpenBuilds OX CNC MachineReplies: 11Last Post: 16-06-2015, 02:16 PM
