    Quote Originally Posted by Nealieboyee View Post
    Interesting idea. Problem is the ballscrew isn't long enough to allow the bearing blocks to reach each end of the raised sides...
    Could you not alter your mould to reduce the length of the raised sides relative to the base?
    I could, but my linear rails run the full length of the raised sides. I'd have to shorten them and reduce my cutting area along Y axis.
  1. BUILD LOG: A new hope: Epoxy granite and steel.
    By hardenum in forum DIY Router Build Logs
    Last Post: 27-01-2021, 03:59 PM
  2. Big Epoxy Granite machine, Which frame is better ?
    By EZELab in forum Gantry/Router Machines & Building
    Last Post: 18-09-2020, 11:18 PM
  3. BUILD LOG: Epoxy granite vertical mill build log
    By Nick in forum DIY Mill Build Logs
    Last Post: 08-06-2020, 06:30 AM
  4. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  5. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
