    Hi all, I am new to CNC and the forum. I have recently built an Ooznest workbee CNC 1500 x 1500 and I've fitted a spoiler board and when I have come to surface it, i have run into the issue of the router coming down but not enough to reach/cut the spoilerboard. I am on Vcarve pro and I have set the cut depth to 0.3 mm and the start depth to 0 mm. I have used an xyz touch probe that came with the machine to show it where the spoilerboard surface. I am going mad trying to sort this out so if any CNC wiz can help me figure out this problem it would be greatly appreciated.
    Thanks.
    ZASto's Avatar
    Lives in Belgrade, Serbia. Last Activity: 6 Hours Ago Has been a member for 5-6 years. Has a total post count of 49. Received thanks 1 times, giving thanks to others 1 times.
    Which software do you use?
    I use Vectric Vcarve pro
    Quote Originally Posted by NewtoCNC___ View Post
    I'm assuming the Z-axis and cutter do actually reach the spoil board in terms of the cutter can touch it.?
    If so, then I think your problem could be that the height (thickness) of the touch probe is set wrong in the control software so it's telling the controller the surface is higher than it really is.
    The easy way to test this is to simply very slowly jog the tool until it just touches the surface and then ZERO from this point.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Thanks.
    You say 0.3. Don't you mean - 0.3 (negative)? As in below zero.
    Thanks.
    Quote Originally Posted by dazp1976 View Post
    Vectric doesn't require you to type the negative, you just enter the depth as a positive number and it converts it to negative when it posts..!! . . . Which does raise the question.?
    Are you using the right post processor for your controller.?
    Also make sure start depth is zero
    Two questions:does the operation simulate correctly in Vcarve?Does the Gcode output from the example in post#8 include the description G01 Z-4.35?
    Quote Originally Posted by routerdriver View Post
    Yes it simulates correctly it’s how one checks to make sure programming mistakes.
    Yes that’s why I posted a picture because it says depth so no minus needed, but it post out g1 z-4.35
  1. 1mm end mill depth of cut in aluminium.
    By Nealieboyee in forum General Discussion
    Last Post: 09-02-2020, 10:01 PM
  2. Way out of my depth
    By jenxmetalworks in forum New Member Introductions
    Last Post: 17-03-2017, 07:42 PM
  3. help needed boring 8mm holes 20mm depth in Alu
    By Noplace in forum Metalwork Discussion
    Last Post: 24-04-2016, 01:27 PM
  4. solidoworks tapped thread depth and blind hole depth
    By reefy86 in forum CAD & CAM Software
    Last Post: 10-11-2015, 04:14 PM
  5. Calibration issues, advice needed
    By Kernow Jim in forum Motor Drivers & Controllers
    Last Post: 23-01-2014, 07:18 PM
