    Any recommendations for accurate limit/homing switches for a smallish mill? I'm thinking probably hall-effect rather than mechanical but that's only an uneducated bias :)
    TIA, Alan
    LJ12A3-4-Z/BX or similar - cheap as chips from China.
    What you using as a controller Alan ?
    Some of the new chips use soft-limits - works on voltage drop.
    Or you could hard stop it save wiring like mine :)
    Ralph Waldo Emerson
    This is an old Gecko G540. Call me old-fashioned but would prefer an 'actual' switch. I'm getting the sense that LJ12A3-4-Z/BX and the like are ~5-20μm repeatability?
    Alan
    Probably much better than an 'actual' switch as there are no mechanical parts to wear out. LJ12A3-4-Z/BX is used extensively in industrial process automation. It would be interesting to see some actual figures on the accuracy of sensing for both inductive and mechanical switches, especially in a swarfy environment. I am discounting Hall switches at the moment. For some reason I do not regard them as the best solution for positional sensing on a machine tool. (Although I would like to hear arguments for and against the case).
    I did some testing on my gantry homing, putting a line on the stepper shaft and it came back to exactly* the same position every time, no matter how far away it homed from**.
    Exactly* is an observation of angle of the line, not a measurement with a dti or similar.
    ** Mach3 homing would compensate for this, by doing an approach and back-off.
    LJ12A3-4-Z/AX
    NPN-NC (normally closed) type or similar is preferred for me.
    If you get a signal wire break it will see it.
    A normally open type will not see a broken signal wire and let you carry on.
    Appreciate that, but I use a mechanical switch NC as a limit switch, 5mm on from the home position.
  1. Proximity switches or limit switches
    By chillybo in forum Gantry/Router Machines & Building
    Last Post: 29-06-2021, 11:50 AM
  2. What Limit Switches?
    By Chaz in forum General Electronics
    Last Post: 14-12-2016, 10:50 AM
  3. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  4. The best solution for limit / home switches on a mill is .....what ?
    By NICKMODELMAKER in forum Gantry/Router Machines & Building
    Last Post: 29-05-2010, 01:38 PM
  5. Limit Switches
    Last Post: 27-06-2008, 02:21 AM
