    Hi, has anyone any experience with this spindle motor pulley on my Bridgeport Interact 1 series 2. I am changing the motor but wanted to reuse the pulley. I can get a 3 leg puller onto it but even with heat and a ton of force it only moved 1/8 of an inch and is now locked solid. It has two grub screws on the top (pic) which I have unscrews but wondered are you supposed to remove this type with an hydraulic feed contected to these two grub screw holes?
    Any help appreciated.
  2. misaligned keyway - stepper shaft vs pulley
    By dsc in forum Stepper & Servo Motors
    Last Post: 25-02-2014, 03:25 PM
  3. pulley fit on motor shaft - force it on?
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 09-08-2013, 06:11 AM
  4. 16 tooth pulley HTD5 15mm on a 14mm shaft
    Last Post: 07-06-2013, 11:51 AM
  5. Stepper shaft size and pulley bore size problem
