Page 1 of 3 123 LastLast
    Anyone figured out how to inexpensively source a Fogbuster into the UK? I see the US site doesn't even have on-line ordering - very old school.
    Alan
    Quote Originally Posted by alanambrose View Post
    Alan
    Not possible, Fogbusters are expensive even if bought in the UK. However, they are good.
    I think Stoney CNC in Ireland sells them.?
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Alan
    Good luck with that one.
    I all but give up on sourcing machine related stuff in the u.k.
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Stoney CNC do sell them - https://www.stoneycnc.com/cnc-compon...ooling-systems
    I made one for my old Novamill. They aren't complicated, and the key is in the pressurised coolant source and the mixer.
    Just done a quick search, and these are the plans I roughly followed - https://www.cnczone.com/forums/uncat...nt-mister.html
    And this was the coolant I used - https://www.johnnealeltd.co.uk/shopenvirocutse10.html
    i followed the same design as m_c. It works really well and cost under £30
    FWIW Sorotec in Germany stocks them on a 2 week wait.
    A.
    OK a follow-up on Fogbuster for anyone looking at this:
    + I sourced one from Sorotec. As I said above, the key parts seem to be metric although there are a few 1/2" and 3/4" fittings in the kit just like any piped work in EU/UK. Note that it comes pretty much as a kit of parts to assemble. The main inlet air fitting supplied is a Euro / XF one (at least from Sorotec).
    + The instructions are badly written and not clear and I think the design needs a bit of refinement. Eventually I found that the product photos on the Sorotec site actually show how the thing goes together. The shortcomings are: (a) because of the placement of the gauge and the 'contents height tube' - the container / valve assembly is really designed to sit on the left of the spindle - I had originally planned for it to sit on the right, (b) you really need to use a clough42-like loc-line on a mill - you might get away with Fogbuster's magnet base on a lathe, (c) the things doesn't sit securely on its base and is top-heavy - so it needs a support of some kind.
    + I used something like clough42's loc-line and 3d printed holders for the flow valve assembly. That's *much* better than Fogbuster's magnet base idea. I'm going to use neat IPA in it (like Stefan G) as I do mostly aluminium. Also, i plan to fit a CNC-controlled on/off valve. I think Fogbuster should supply the loc-line / holder as standard or at least as options. Also, various support options to stop it falling over e.g. a base. Also you need a funnel to fill it, so put one in the kit please for a cost of 10c or at least tell your customers up front.
    + a gotcha - although I looked under a magnifier, I didn't twig that the 6mm->M5x0.8 shark-bite fittings take an internal 2.5mm key to tighten them. I had to order replacements from Cotswold. Did they put that in the assembly instructions - nah, why would they?
    Something I realised afterwards- I really wanted something to remove chips so I can leave the CNC-mill unattended for longer sessions and avoid chip re-cutting quality and breakage problems. While the Fogbuster will work well for that and I can see benefiting from MQL in some circumstances, I could have probably got away with a targeted and controlled air blast for 90% of my needs as I usually cut dry.
    I still have to use it in anger and there's a non-return valve niggle to sort. That's all for now though - if I remember I'll post back when I have some better experience with it.
    Alan
    p.s. I didn't see this before, but I see Stepcraft have an MQL system also:
    https://shop.stepcraft-systems.com/lubrication-system
    A.
    I purchased a fog buster from American some time back. Save your money. It’s a next to useless bit of kit. In the end I made my own using a water filter and some fittings from eBay. Cost less then £25. The fog buster sits under the work bench collecting dust.
  1. Sourcing CNC kit from EU
    By warrenfalzon in forum Marketplace Discussion
    Last Post: 18-01-2017, 08:52 PM
  2. Sourcing a servo motor. Help!
    By oscar in forum Marketplace Discussion
    Last Post: 22-08-2013, 01:06 AM
  3. CNC Novice, Looking to build, little help? Design, Sourcing and General Help
    By kylelnsn in forum Gantry/Router Machines & Building
    Last Post: 29-02-2012, 01:32 PM
  4. sourcing material for a DIY build
    By mmcp42 in forum Gantry/Router Machines & Building
    Last Post: 01-01-2011, 10:23 PM
  5. sourcing transformers
    By adscnc in forum General Electronics
    Last Post: 20-11-2010, 11:05 AM
