25-10-2015 #1
Has anyone here got any experience using ethanol delivered via a mister system when high-speed cutting aluminium? I understand that's what Datron use in their machines. At the moment I'm using WD40 which works but makes a horrible sticky mess when mixed with aluminium chips/dust and tends to stink the workshop out. I also have issues with the WD40 separating in the mister reservoir (the bottom of the tank ends up with white fluffy looking stuff floating around in it).
Are ethanol fumes an issue? Where can I economically source ethanol, in appropriate form, a few litres at a time? So far I've only been able to find bioethanol (the purity of which I'm unsure about) and methylated spirits (which probably smells worse than WD40) in bulk.
Cheers,
Matt.
Dry Aluminium Cutting Problem
By Tenson in forum Tool & Tooling TechnologyReplies: 22Last Post: 29-08-2016, 11:41 PM -
Aluminium cutting
By Bush Flyer in forum Metalwork DiscussionReplies: 55Last Post: 13-05-2016, 09:57 AM -
WANTED: Mist lubrication system
By badgerman in forum Items WantedReplies: 9Last Post: 21-08-2014, 12:28 AM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM
