My Mach3 5 axis controller board came today and although there was a lot of documentation supplied with it, there was not enough to setup the board properly.
All the stepper motor settings are shown as 0 for all the steps pins and all the dir pins. I know that is not right, but how do I determine which are the correct settings? Can anyone help me with this?
Board name is JDSW51B
09-07-2021 #2
09-07-2021 #3
Doddy, where are you getting that he's using an NVEM controller from.? That picture is of a standard BOB.!
Regpye, this link is a better manual and may help, if you don't understand it just say so, and will talk you throw it.
https://www.steppermotorcanada.ca/bl5breakoutboard.pdf-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
09-07-2021 #4
First google hit I found on that board number confirms the above.
https://www.duxe.ru/upload/iblock/40...c4d2421927.pdf
09-07-2021 #5
OK, thanks guys, I will cross my fingers and give t a try
09-07-2021 #6
Thanks jazz, read page 5 of the link you provided, same as the link I provided from the Russian site to back off the analogy i first posted. My first post clearly started the info from the different card and was what I had to hand at the time.
My recommendation remains, try it as is, the provided driver software hard codes the output mapping
09-07-2021 #7
That's my point it's just a standard BOB, not a motion controller like the NVEM so the MOTOR OUTPUTS will need to be set up. Not having a pop just wondered how you thought it was a NVEM or motion controller.?
A note for REGPYE: You will also need to apply 12-24V for the inputs and outputs to work, it basically power the optos. See Diagram on page 2, just above the inputs you have 12-24v connectors.-use common sense, if you lack it, there is no software to help that.
Hi JAZZCNC
Friday? Pub?
Mach3 knows nothing about USB, so definitely the board is an motion controller.
On the picture:
http://www.mycncuk.com/attachment.ph...811440&thumb=1
is clearly visible a micro controller (no matter which type but looks as some STM32Fxxxx).
So, motion controller with BOB :)
09-07-2021 #9
Hi ZASto, No not the pub but I am not myself today, poorly sick and dying from food poisoning, ate some dodgy fish I think..
To be honest I didn't look that close to see it only had USB and no PP. I don't use BOB's these days and most I've seen like this have a USB port so just assumed it was standard BOB,!! , , , , You know that they say about assumptions being the mother of all FKUP's ...-use common sense, if you lack it, there is no software to help that.
09-07-2021 #10
Thanks Jazz, that manual has a bit more info than mine.
I will test out the system later today when I get dressed, it is 5am here in Australia and cold too.
The project I am working on is a plasma cutter that has a standalone THC with a DC motor, so I only need to use X and Y axis with Mach3.
Because the table is wide, I will be using two stepper motors and will need to slave Y and A together. I might have some homing and limit issues to deal with later.
I have already changed the Ref All Home button to allow homing of only the X and Y
DoButton( 22)
RefCombination( 10 )
I guess I will find out if it works for real later, it works on the screen OK.
The THC has a DC motor and is fully automatic, but I will still need to lift and lower when setting a job up, so I will use real push buttons to do that. There are not enough inputs and outputs available on this board to allow some keyboard macros to control a couple of extra relays needed for that part (unless it is possible to reassign some unused pins maybe?)
Please help - missing steps ... Mach3
By emilvv in forum Artsoft Mach (3 & 4)Replies: 21Last Post: 23-12-2019, 08:31 AM -
New Mach3 settings but limit switches do not work, using a JK02 breakout board help!
By JimK in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 27-09-2019, 11:54 PM -
switches settings in mach3
By Palletlad in forum General DiscussionReplies: 2Last Post: 17-09-2019, 05:40 PM -
Mach3 turn screen missing items / incomplete?
By mondrota in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 27-02-2018, 06:30 PM -
Help withController dip switch settings and Mach3 motor tuning
By liamo1991 in forum Motor Drivers & ControllersReplies: 2Last Post: 15-11-2013, 02:22 AM
