Thread: A3 Marchant Dice Kit
18-02-2010 #11Ahhh yes! there has been, but i've been a bit busy at home with other problems since the New Year: water leaking through the ceiling type problems to be exact:cry:. However thats now all fixed and decorated so I set my sights back on the CNC only in the past fortnight.Any progress Neo ?
Those that have been following the progress will be pleased to know a few weeks ago I managed to purchase a SFF PC (small form factor) PC dedicated to my CNC off good ol ebay for a few pounds. Plus a friend gave me a flat screen monitor with a scratch on the screen for free. (you can't see the scratch when its on).
I duly installed a fresh copy of XP and Mach3 and started it all up. After a crash course in Mach3 and setting it up, much to my surprise it worked first time!!!:dance:
After playing with the JOG control for what seemed like hourslol
The first successful test was on the settings section of Mach when I requested to move the X axis 25cm and it did. the same for the Y axis and so on. First test complete.
Overjoyed with how accurate it appeared to be, I found a pencil and installed it in the Kress and then watched it happily drew out a picture of the skull and crossbones from the sample section of Mach3. I did the same with the Roadrunner picture too.
All very accurate reproductions but very small. Are these examples supposed to be only a couple of cms in size? :question:
Anyway, I set the scale to x2 and it made it a bit bigger and I think The CNC mill passed its first test.
Pleased as punch I set about ordering a couple of end mills to start with, they arrived this week and my son's been playing around on a CAD program with a few simple test subjects. This weekend I'm hoping to make a few cuts....
I'll keep you all informed.........
Neo
Marchant Dice
By agent17 in forum Marketplace DiscussionReplies: 28Last Post: 06-06-2020, 11:06 AM -
Marchant Dice router no thrust bearings?
By gavztheouch in forum Marchant Dice MachinesReplies: 56Last Post: 05-09-2016, 02:23 PM -
CNC-Step High-Z S-400 or Marchant Dice MDL-2-TR ?
By No1_sonuk in forum Heiz CNC RoutersReplies: 10Last Post: 20-04-2009, 12:39 PM -
Marchant Dice on eBay
By irving2008 in forum Marketplace DiscussionReplies: 4Last Post: 06-09-2008, 05:37 PM
