  1. #13
    neo's Avatar
    Location unknown. Last Activity: 19-08-2012 Has been a member for 9-10 years. Has a total post count of 8.
    Part2 The Krypton factor
    Before the missing parts were sent, building the base was not without its challenges.
    Remember there are no instructions which to be fair is not a major
    problem, it really is fairly straight forward to construct, although a mechanical mind should help.
    However, the trouble was the Y axis base didn't seem to fit together properly and I just couldnt work it out. The Z, X axis top section went together relatively easily, but I based the building of the base on what I'd learnt with the top part and this turned out to be where I was going wrong.
    It became like an insolvable puzzle as I tried to put the side rail fixings into the same diagonal position as seen on the top part. in fact the more convinced I became thats how it should be attached, the more impossible it became to attach the cross member. It simply wouldn't fit and I couldn't see the wood for the trees.:confused:
    After much cursing and wondering if I should have bought a crate of beer instead
    I had a brainwave of looking on the internet at some pictures I'd seen on good old ebay when i was looking at buying the unit.
    I recalled that the listing for the CNC in question had a link to some photos of one already built.
    There was a series of photos in closeup of a tour around the machine. In one photo it clearly showed the base side rails fixed in the same diagonal postion as the upper part.
    What I didn't realise was this was a photo sequence of an A4 machine, I'd bought the A3 machine and unbeknown to me it had subtle differences!!:heehee:
    By trial and error I started to fit the rail fixings in the same slots as themselves and it was only then that I could succesfully fit the cross member to join the two parts together.
    Unfortunately I wasn't convinced I was doing it right afterall the photo sequence shows them to be diagonal.
    It was only by looking closely at a smaller photo of the A3 machine that I could see the rails were indeed fitted in the position which I was now using. I was right but boy did my head hurt trying to solve the krypton factor!
    Once I realised I was on the right road I was happy to tighten the screws up and complete the base unit.
    The photos also had another advantage in that one photo also showed the elusive missing specialised nuts.
    I now knew what was missing all I had to do was wait for them to arrive
    Neo
    part3 to follow.....
Name:	7top fixings.jpg
ID:	1231   Click image for larger version.
Name:	8 y rails.jpg
ID:	1232   Click image for larger version.
ID:	1233   Click image for larger version.
  1. Marchant Dice
    By agent17 in forum Marketplace Discussion
    Last Post: 06-06-2020, 11:06 AM
  2. Marchant Dice router no thrust bearings?
    By gavztheouch in forum Marchant Dice Machines
    Last Post: 05-09-2016, 02:23 PM
  3. CNC-Step High-Z S-400 or Marchant Dice MDL-2-TR ?
    By No1_sonuk in forum Heiz CNC Routers
    Last Post: 20-04-2009, 12:39 PM
  4. Marchant Dice on eBay
    By irving2008 in forum Marketplace Discussion
    Last Post: 06-09-2008, 05:37 PM
