    Its working .. as in the laser comes on at very low power and creates a spot. But if I use test software in light-burn that ramps its from 10% to %100 its get brighter but wont even draw a line on paper - it goes through the file doing the same thing. Not sure what is wrong. If I press the fire button on the laser motherboard it instantly burns a hole in the paper.
    Ralph Waldo Emerson
    videos of problem added
    focus test
    onboard full power button burn
    Off to get a new Arduino from CPC see if its the cheap clone problem
    Ralph Waldo Emerson
    I know nothing of the hardware, nor software. But, ultimately this will be a TTL-level signal between whatever controller and the laser. Gut feeling is you've got a PWM output on the ardi that is either "wrong" (maybe duty cycle?, or some internal calibration), or the software is mis-configured. If you've got access to a scope I'm be examining the signal to the laser and taking it from there. If you get stuck - I'm local, can offer a second pair of eyes and a scope.
    I've swapped out the Arduino still same result.
    I've red that if the feed rates are to low it will not power up because it will burn. But I think its a faulty laser motherboard. I've seen these working on much lesser machines on youtube. I've sent the video to the maker.. see what they say.
    But I might bypass diodes and fit a C02 to it.
    Ralph Waldo Emerson
  1. NEJE laser engraver question vector instead of raster
    By Richard in forum Laser Machines & Building
    Last Post: 21-02-2019, 05:29 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. Plunging and ramping speeds
    By gavztheouch in forum Machine Discussion
    Last Post: 15-06-2014, 12:49 PM
  4. eBay: 40W CO2 Laser Tube + Power Supply + More
    By Lee Roberts in forum Items On eBay UK
    Last Post: 06-12-2013, 08:23 PM
  5. Laser power
    By John S in forum Laser Machines & Building
    Last Post: 26-08-2009, 09:53 PM
