Thread: UCCNC shuts down unexpectedly
16-07-2021 #11
I still think it's a Windows installation problem. It's a good idea to start with the windows repair tool, but beware ONLY use repair tools which are issued by Microsoft. DON`T go for any other versions. Next step, if the Microsoft tool doesn't find any errors is to reinstall Windows.
Actually, if you have a known date before the problem then you could go back to that date (minus a few days) and try a Windows recovery from there. Windows will uninstall everything installed after that date. Note that only drivers and updates of Windows will be uninstalled. Software you have installed after that date will still be there, but if it needs any interaction with Windows it may no work and must also be reinstalled / repaired.
BTW, during all the years with W10 I have never ever had an ntdll.dll error. I don't understand why you say it's a known case. It can however be the result of unintentionally having removed something which is necessary for windows. Admittedly, I am not using any other UCCNC plugin than the Modbus master, but I think that the X-Box pendant is so popular and widely used, so it should have been quite intensely tested. Also, that plugin is very old, it is still the same version as from the start. This can of course be a problem in some cases, if Windows or UCCNC requires that, but it should be known in that case. Have you checked on CNC Drive forum?Last edited by A_Camera; 16-07-2021 at 08:57 AM.
Uccnc and rasbery pi
By valdis034 in forum General DiscussionReplies: 2Last Post: 12-11-2020, 05:26 PM -
UCCNC intrusive pendant
By John11668 in forum General DiscussionReplies: 2Last Post: 29-07-2020, 10:39 AM -
UCCNC with UB1 Sanity Check
By iforeman in forum CNCdrive (UCCNC)Replies: 6Last Post: 23-06-2020, 06:42 PM -
Uccnc software question
By jtar40 in forum General ElectronicsReplies: 2Last Post: 11-11-2018, 12:44 AM -
UCCNC MyProbe error
By chipxx in forum CNCdrive (UCCNC)Replies: 0Last Post: 22-08-2017, 02:36 PM
