Which leads to two possibilities;either the Z datum is incorrect or the machine does not have sufficient travel.If you use the process described by JazzCNC in post #4 it should do the job.Do you understand how to change the Z datum for the progam?
19-07-2021 #2-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
1mm end mill depth of cut in aluminium.
By Nealieboyee in forum General DiscussionReplies: 11Last Post: 09-02-2020, 10:01 PM -
Way out of my depth
By jenxmetalworks in forum New Member IntroductionsReplies: 18Last Post: 17-03-2017, 07:42 PM -
help needed boring 8mm holes 20mm depth in Alu
By Noplace in forum Metalwork DiscussionReplies: 6Last Post: 24-04-2016, 01:27 PM -
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
Calibration issues, advice needed
By Kernow Jim in forum Motor Drivers & ControllersReplies: 16Last Post: 23-01-2014, 07:18 PM
