20-08-2021 #15
Hi Archy,
That neck was finished with a 1mm steover parallel pass. I could have quite easily set it to something lower but it would increase machining time. Hell, I could have set it to 0.1mm stepover but personally I dont see the point. You are going to be sanding the neck anyways, It may appear to you like there are alot of machining marks, but 120 grit sandpaper will have that neck smooth in a matter of minutes. Plus, with something like a neck it is going to be refined further before completion, the shoulders of the neck will need blending with the fretboard as I have left the neck a little wide to give me a bit of wiggle room when glueing the fretboard on.
The top carve went really well. I believe on that I ran a "Morphed Spiral" operation from fusion 360 and in that instance set my stepover to 0.5mm as the top is maple so a bit more effort to sand. At 0.5mm stepover you would have needed a magnifying glass to see the scallops.
regards
Ben
Further Progress with my JazzCNC .. Guitar Body
By BeeceUK in forum Woodworking Project ShowcaseReplies: 7Last Post: 23-04-2021, 06:25 AM -
NEW MEMBER: Guitar Building CNC Newbie
By BeeceUK in forum New Member IntroductionsReplies: 18Last Post: 26-09-2020, 05:04 PM -
Jazzcnc, the right choice in a custom made machine
By alex wight in forum General DiscussionReplies: 17Last Post: 18-10-2016, 07:39 PM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
NEW MEMBER: CNC and other Machine Building Berlin
By Andikid in forum New Member IntroductionsReplies: 1Last Post: 07-10-2010, 11:30 PM
