Thread: Fusion 360 post processor
I thought .nc was the default output, but then it's probably what is set in the post processors I happen to use.
If the post processor file you're using is set to tap, and everything else is ok, open the post processor.
Either from within F360 - manufacture -> 'manage' drop down menu -> Post Library, then in the new window right-click on the post, and select Edit, or alternatively find).
or in the local storage folder - C:\Users\<user>\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts
You need to change the extension = "nc"; variable (it's near the top).
Then save the file, and it should be updated next time you post code in F360.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Adding a post processor
By DaveC in forum Fusion 360Replies: 4Last Post: 17-08-2020, 09:53 AM -
Post processor
By DaveC in forum Tool & Tooling TechnologyReplies: 5Last Post: 03-08-2019, 09:43 AM -
Post Processor for Heidenhain tnc 145???
By jackpat in forum CAD & CAM SoftwareReplies: 15Last Post: 04-07-2016, 10:17 PM -
Help with Post Processor
By superpot in forum CAD & CAM SoftwareReplies: 0Last Post: 20-11-2013, 11:23 AM -
Post processor Sei
By 2006Nobull in forum Machine DiscussionReplies: 12Last Post: 04-08-2011, 12:58 PM
