Thread: Looking for help from Jazzcnc.!!
25-07-2021 #7
Well I was about to say if it's not a mechanical issue then it could be a step edge issue but if it's one my machines and no one else as messed with settings in the control software then it won't be that as we check every machine for this by doing a bounce test.!
If you want to check this then it's very easy. Zero the Z axis and put a reference mark on it so can check it comes back to zero. Next write some gcode with a few 100 short moves, something like this:
G0 z-10
z-5
z-10
z-5
z-10
copy and paste untill got 200+ lines
ending with
z0
m30
If all correct then it should come back to the Reference mark. If not then go into Ports n pins / Motor outputs and change the Step Low active to the opposite of what's it's set at now. So if Ticked make it a X.
Then Zero and mark again and run code again, this time it should come back to mark.
But before doing all this check for loose pulleys or belts as often it's a mechanical issue which causes it.
Which machine is it.? I don't remember selling one to anyone called Billy.?-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Guitar Building with my JazzCNC machine
By BeeceUK in forum Woodworking Project ShowcaseReplies: 19Last Post: 26-09-2021, 10:53 PM -
Further Progress with my JazzCNC .. Guitar Body
By BeeceUK in forum Woodworking Project ShowcaseReplies: 7Last Post: 23-04-2021, 06:25 AM -
Jazzcnc top geezer
By Edendale in forum General DiscussionReplies: 18Last Post: 15-02-2020, 01:25 PM -
Jazzcnc, the right choice in a custom made machine
By alex wight in forum General DiscussionReplies: 17Last Post: 18-10-2016, 07:39 PM -
EXPERIENCE: Working with JAZZCNC
By m.marino in forum Trading Experience & FeedbackReplies: 0Last Post: 02-10-2012, 11:47 AM
