Threaded View
    have i bit off more than i can chew...maybe time will tell
    i wanted a bigger mill , i currently have a denford triac atc running off mach3 which i will end up selling .
    so i bought from a friend a far too big vmc for my home garage .
    it has a 7.5kw spindle 3ph
    control techniques vfd
    centroid m400 controls
    bt40 atc
    centroid servo motors
    linear guides
    rtk3 control board
    32mm lead screws
    etc.
    unfortunately the base and z tower castings are massive
    knowing it was physically too big the plan was too break it down ,
    cannibalise the parts i could reuse and build myself a machine from scratch with 240v 1ph supply .
    so i will need to build a frame to mount the y axis and z axis on
    i plan to use the original table with the original x axis
    so i will need some help in the design ,im in no rush i suspect it will be a year or so before its finished but guidance on the best direction to go in will be a great help .
    i will definitely keep the ball screws linear guides x table . hopefully the servos and their controller if i can modify the rectifier with a big capacitor for 1ph.
    i would like to keep the m400 and rtk3 but i imagine the plc will need modifying by someone who knows their onions .
    but if not maybe centroid acorn and a pc
    i have a feeling the very heavy 7.5kw 3 ph spindle will be too much so that may have to go and something smaller may be required .
    any help
    do's
    don't do's
    would be appreciated
    thanks
ID:	30282   Click image for larger version.
ID:	30283   Click image for larger version.
ID:	30284   Click image for larger version.
  1. RFQ: Semi automatic welding system Linear beam control system
    By richway in forum Projects, Jobs & Requests
    Last Post: 24-01-2017, 08:54 PM
  2. BUILD LOG: Small scratch build 3 axiz CNC
    By bofred in forum DIY Router Build Logs
    Last Post: 08-04-2015, 06:58 PM
  3. Semi - Experienced / Experienced CNC Turner required in Rutland
    By ChrisMunday in forum Opportunities Available & Sought
    Last Post: 05-02-2014, 11:08 AM
  4. New CNC mill build
    By AVRnj in forum Milling Machines, Builds & Conversions
    Last Post: 13-04-2013, 12:19 PM
  5. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 03:16 AM
