Hi, thanks for the reply. Sort of... I can't see any movement as such with a dial gauge, however I perhaps should have mentioned this only happens for the first 40mm (ish) from the chuck face. If I use a thicker bar with a tailstock and make a cut 70mm from the chuck face the cut is as smooth as a babies bottom - which why I was thinking worn ballscrew (coupled with the ballscreww being 5mm and the tramlines also being 5mm.
thanks again for th reply.Every time I am wrong - the World makes a little less sense.
Help on fault finding on a C3-31 Hammer combination machine
By OMLCNC in forum Workshop & EquipmentReplies: 49Last Post: 18-12-2017, 12:58 PM -
Opto isolated Bob and drivers causing a strange fault.
By lucan07 in forum General ElectronicsReplies: 2Last Post: 02-05-2016, 09:28 PM -
Plasma cutting fault diagnoses....
By Davek0974 in forum Plasma Table MachinesReplies: 15Last Post: 01-04-2014, 07:04 PM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM -
Looking for Lathe Cutting Tools
By Zeeshan in forum Tool & Tooling TechnologyReplies: 2Last Post: 06-09-2011, 09:50 AM
