  1. #3
    Gets my vote, in principle at least. I'd be interested in critiquing component value selection (just look/work around the opto CTR)
    Hopefully this is relevent.
    A quick read of 300eth manual again.
    The 5v is a pass through from my seperate psu which is supplying it.
    Into the controller from my psu (using a 5v 3A) to power it's logics and passing through to pin 26 for powering additional I/O.
    States :Minimum for controller = 500ma. Higher needed for adding extra I/O.
    All output pins TTL max 20ma. Inputs TTL 0/5v levels.
    Took the 5v in diagram from Pin 26 on port 5 for convenience due to it being right next to opto board in the box layout.
    Psu itself is further away.
    (Will look at opto model number when it turns up)
    I actually already have a UCBB under power from Pin26 on port 1+2 already for axis controls.......
    ........(16 outputs - 18 inputs - high speed chips - 7HC types or something. Can't read them atm).
    So it must have the guts in it to run a bunch of diodes!.
    The diodes are actually just to show which port the fault is on. They only light if opto is active.
  1. Wiring Diagram check
    By eurikain in forum Electronic Project Building
    Last Post: 08-12-2017, 08:40 PM
  2. Which wiring diagram software do you use ?
    By eurikain in forum Computer Software
    Last Post: 11-10-2015, 02:48 PM
  3. VFD Wiring Diagram
    By Tomnewry in forum General Electronics
    Last Post: 14-10-2013, 06:46 PM
  4. Wiring diagram for 4x4 cnc router
    By Danielroyal25 in forum General Electronics
    Last Post: 19-07-2013, 11:14 PM
  5. NEW MEMBER: Hi, Looking for a wiring diagram, Melbourne
    By Sampop in forum New Member Introductions
    Last Post: 28-10-2010, 11:18 AM
