    Been mulling it over, think I need to heed the advice of those in the know.
    PP BOB - RIP.
    Going to go for the uc300, and actually get on with making some stuff.
    Sent from my SM-G981B using Tapatalk
    Quote Originally Posted by 703E5 View Post
    PP BOB - RIP.
    Wise choice, but if you don't need all the I/O the UC300 offers then you may find the Axbb-e is the better option as it's much neater and comes with BOB built into it, the UC300 still needs a breakout board to be safe. Both the Axbb-e and the UC300 are identical regards the motion controller side so the UC300 offers nothing extra other than more ports (I/O)
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    The only real difference between the 2 is the secondary analog output and the way you install a 5th/6th axis. And of course the 300 needs bob's or equivelent.
    1. Some servo's use 2 analog inputs for hybrid speed/torque mode. If required, use uc300.
    2. Some have problems adding a 5th/6th axis to the Isolated outputs on bbe. Opto's seem to be non high speed (basically for switching). If you need to use a high khz kernel for pulses then use the non-isolated outs on port3 with a high speed bob (ucsb type + IDC26 cable).
    Other than that the controller is exactly the same.
    Haven't fired up my 300 yet, but the unit looks like a 'proper job'. Big step up from my £5 thing
    Quote Originally Posted by dazp1976 View Post
    Not exactly correct, I think you maybe don't understand how the Speed/Torque mode switching in servos works.?
    You don't need 2 analog 0-10v OUTPUTS from the controller to use this feature on a servo. You just need Digital OUTPUTS which connect to Digital INPUTS on the servo drive to signal the mode change, you still use the same Analog speed reference output from the controller to command the speed or torque.
    The Servo Drive just changes tuning parameters etc when it sees the Digital inputs change. The same is true when switching from High to Low-speed range on a servo spindle drive or going from Speed to Position mode for ridged tapping. All done using the same Speed reference input, whether that be digital or Analog, just controlled and switched using digital Inputs.
    However, to the OP this isn't really relevant as he's using a stepper-based system and if he was it wouldn't be an issue provided he didn't need more I/O than the AXBB-E offers.
    In fact, for the OP the AXBB-E is a better option than the UC300 + UCSB or UCBB combo because it comes with dedicated Analog Output built into the BOB which is protected, the UCSB and UCBB don't offer this so you need some external protection if you want to be safe. It's also upgradable with an additional BOB if more I/O is required.
    I fit both the AXBB-E and UC300 to machines and to me for most stepper-based machines that don't run an ATC spindle or require lots of I/O then the AXBB-E wins hands down for its neatness and simplicity in one single board and it's not exactly short of I/O for most machines. The ratio I fit is at least 20:1 in favor of the AXBB-E.
  1. NEW MEMBER: Will run out of HAIR SOON
    By 703E5 in forum New Member Introductions
    Last Post: 31-07-2021, 07:27 PM
  2. need a part... and pulling my hair out now
    By flotsam in forum Lead Screws, Nuts & Supports
    Last Post: 19-04-2021, 04:12 PM
  3. pulling my hair out with cam
    By universally in forum CAD & CAM Software
    Last Post: 09-04-2015, 01:41 PM
  4. Hair growth device. DIY version
    By gavztheouch in forum Electronic Project Building
    Last Post: 30-03-2014, 08:55 PM
  5. AM882,s and Mach3 ......plus hair removal !!!
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 26-10-2012, 05:11 PM
