	03-08-2021 #11
If you go for water cooled you must also add the weight of the cooling water circulating in the system, so a 2.2kW water cooled motor + motor holder + cooling liquid is probably too much for you. Also, don't underestimate the weight of cables, especially if you are going to use good quality shielded cables.
In my opinion, you should go for a 1.5kW air cooled with at least ER16, unless you are absolutely sure ER11 is enough for you. Those motors are lighter, and noise wise you can't compare them with a Kress or your Makita router. These motors are quiet (sort of), even at 24k rpm. Anyway, while water cooled are surely more quiet, the cutting noise will take over and bring it to the same or similar level when used for real work.
If you want to listen to my motor you can do that in this video.
Note that in the video, the VFD fan noise is almost always louder, and also that I made a mistake, had the microphone gain too high during the recording. So in reality, the spindle (when cutting air) is surprisingly quiet, compared to many other machines, like an angle grinder or a Dremel, and definitely all the routers I have ever heard.
It is an air cooled, 65mm diameter with ER11, and the only thing I'd change if I had to start over is that I'd buy a motor with a square house and an ER16. I'd still use air cooled.
NEW MEMBER: New Member intro
By Old Silver Fox in forum New Member IntroductionsReplies: 0Last Post: 06-05-2015, 08:02 PM -
NEW MEMBER: New Member Intro
By BigdogBro1 in forum New Member IntroductionsReplies: 0Last Post: 29-12-2014, 04:54 PM -
NEW MEMBER: Intro and hello from new member
By Bone in forum New Member IntroductionsReplies: 2Last Post: 07-01-2014, 03:45 AM -
By Bush Flyer in forum New Member IntroductionsReplies: 4Last Post: 12-04-2013, 07:39 AM
