    I have a repeat job requiring centre drilling, drilling 20mm deep and boring to size and realised I could do it with one turret position and leave a tooling block set up for the part if I could use gang tooling in a tool turret holder, provided there was a way of mixing tool types on multiple edges of one tool on the Siemens 808D controller.
    Step 1 was to face some EN8 square on the Syil X7 and drill the holder mounting holes
    Then there were a bunch more holes from various sides with one at 10 degrees in order to make machining the gang tooling holders a 3 Axis milling job. Next the holder was machined on the X7 to almost fill the pocket in the turret (which normally accommodates a tool and clamping wedge), this shows a comparison of my gang holder with the standard holder for drills etc.
    The gang tooling holders were then drilled and reamed in-situ on the lathe to accept 16mm round shank tooling giving me this.
    It turns out that I could have made the holders significantly longer and retained clearance for the turret to rotate, so at some point I will measure the exact clearance and make some longer ones with higher capacity.
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    Gang tooling is brilliant if you make parts that suit it.
    It's the one thing I didn't like about my Cyclone, was there wasn't enough travel/clearance to run any gang tools.
    In this setup have loads of travel and clearance to run gang tooling on up to 3 positions with conventional tooling and a bar puller in the other 3.
  1. CNC Horizontal gang style lathe
    By Davebeck in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 26-04-2021, 07:47 AM
  2. Chester 626 turret mill
    By Robin Hewitt in forum Machine Discussion
    Last Post: 29-08-2017, 04:40 PM
  3. My comical CNC lathe story and does anyone have experience with gang toolposts?
    By Rob in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 16-09-2016, 12:36 AM
  4. Gang Tooling Block
    By Dave Clayton in forum Machine Discussion
    Last Post: 21-10-2011, 09:52 AM
  5. XYZ Proturn SLX355 I want to Fit Gang Tooling Help!!!
    By Dave Clayton in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 21-10-2011, 08:17 AM
