Thread: Close-loop torque control
04-08-2021 #1
Re: closed-loop steppers & torque (as opposed to position) control. Viz:
https://en.nanotec.com/knowledge-bas...oop-technology
"In torque mode, the closed-loop stepper motor functions analogously to a spring, whereby the spring tension characteristic curve can be set via a potentiometer. Thus, the motor delivers a stable force, even when the motor counteracts a force while at a standstill. When the force declines, the motor begins to turn proportionally to the declining force up to the set current and torque values. Thus, closed-loop stepper motors prove ideal for any type of winding, stretching and pressing applications."
I think ClearPath have support for this application:
https://www.youtube.com/watch?v=fHPZ0lqU-80
Anyone know of any others?
Ta, Alan
04-08-2021 #2
Not any that take a pulse input. There are possibly some servo drives that can do it, but it's not a feature I've ever looked for.
Pretty much any modern servo drive that supports analogue +/-10V input, will support torque mode.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
05-08-2021 #3
Nope, I've not seen any closed-loop stepper system other than the Clear path which can do it, and to be honest at the money they want you could get an AC brushless servo which would be much stronger. Thou I'm still not sure they could use a pulse signal to control torque, torque is usually and easily done with +/-10v as MC says. (that said I have some Adtec servos which are pulse only and I think they have torque mode.?, will check that.!)
Email: [email protected]
Web site: www.jazzcnc.co.uk
05-08-2021 #4
The Lichuan, DMM and Yaskawa AC servos all support torque mode although the Lichuan seems to only support analogue (+/-10V) inputs. The others seem to support serial / digital comms etc as well. Step/dir isn't an obvious mode for controlling torque but I suppose the pulse frequency would indicate the torque demand.
My Leadshine closed loop servo only supports position control with step/dir inputs, so I'm guessing this "closed loop stepper in torque mode" function seems to be a bit of a minority sport. I suspect the norm is just to use servos for torque control.
Unless you need true 4 quadrant operation, there are iron powder clutches and brakes that generate a (drag) torque that is proportional to control current. For things like coil winders and tensioners, this may be a much simpler solution but it's not clear what the OP is actually after. https://www.aliexpress.com/w/wholesa...der-brake.html
05-08-2021 #5
Yeah, I think so. And I didn't realise the preference for servos for this application although that makes sense, so thanks everyone for that.
I should have said: the application is a clamping one - needing to produce a given clamping force in the 1-5Kg (~10-50 Nm) range and constant over a variable distance of ~5mm or so. There is a requirement to start at a particular distance (hence my 'stepper thinking') but after that it's a 'closed-loop clamping application'.
Alan
Chinese 'Hybrid Closed Loop' steppers vs 'regular' open loop steppers
By clutchslip in forum General DiscussionReplies: 12Last Post: 12-11-2020, 09:23 PM -
trying to keep the machine close to the cutting area
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 04-12-2017, 11:22 PM -
Use spindle torque to control feedrate?
By Jonathan in forum Tool & Tooling TechnologyReplies: 4Last Post: 02-05-2014, 10:37 AM -
So close.....am882 driver blowing fuse
By Danielroyal25 in forum Motor Drivers & ControllersReplies: 12Last Post: 29-03-2014, 09:32 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM
