    vfjr's Avatar
    Lives in Essex, United Kingdom. Last Activity: 02-09-2021 Has been a member for 3-4 years. Has a total post count of 2.
    EDIT: SOLD on FB marketplace
    Fully working 6040Z CNC with accessories. Used occasionally for personal projects, made out of wood or aluminium, but I've now ordered a larger one due to some planned projects which need a larger bed size.
    Includes:
    -PC with Mach 3 installed and set up
    -20 ish inch monitor with Vesa wall mount included.
    -Keyboard and mouse
    -A nice vice that's great for machining small to medium pieces of wood and aluminium. Currently it's levelled and square, tested with a dial gauge. This is what I used for most of my projects.
    -Tools: some end mills, an edgefinder, a surfacing bit for the spoilboard, a set of ER11 collects
    -Z probe, fully set up in Mach 3. I have also made other inputs from the controller box easily accessible in case you want to add other accessories
    -MDF spoilboard, loads of life left in it, and replacements are easy to make out if you'll need to replace it. The MDF pieces bolt to the aluminium bed, and can be easily removed if needed.
    -Water Pump and small reservoir combo, which i found is more than enough for cooling and water never even got warm. I generally never did anything longer than 3-4 hours in one go on it, but you might want a radiator if you're planning to do much longer jobs in one go. I can either drain the loop or keep it as it is (currently using G13 coolant)
    I am located in RM15 (East London / South Essex), but could potentially deliver myself locally.
Name:	WhatsApp Image 2021-08-29 at 12.54.30 (1).jpeg
ID:	30372Click image for larger version.
Name:	WhatsApp Image 2021-08-29 at 12.54.30 (2).jpeg
ID:	30373Click image for larger version.
Name:	WhatsApp Image 2021-08-29 at 12.54.30 (3).jpeg
ID:	30374Click image for larger version.
Name:	WhatsApp Image 2021-08-29 at 12.54.30.jpeg
ID:	30375Click image for larger version.
Name:	WhatsApp Image 2021-08-29 at 12.54.31.jpg
  1. 6040Z controller
    By RichardR in forum Control Hardware & Systems
    Last Post: 01-11-2020, 10:38 AM
  2. 6040Z controller
    Last Post: 19-10-2020, 02:36 PM
  3. CNC 6040z USB z-axis
    By Sashido in forum Chinese Machines
    Last Post: 26-03-2018, 09:46 AM
  4. Fully supported linear bearings - Radial squareness
    By Slixxor in forum Gantry/Router Machines & Building
    Last Post: 27-05-2016, 08:37 AM
  5. WANTED: 2 x 20mm Fully Supported Round Rail
    By longy in forum Items Wanted
    Last Post: 30-03-2014, 09:21 PM
