29-08-2021 #17
Increases a little. but not a massive amount. Current shows a fair jump (Hard to see the actual amount on a digital MM )but then settles back to a steady current 0.1 -0,2 A increase on before .
It seems to me as if it is not responding quickly enough to the sudden application of cutting load so if the load is not massive it gets to coping after a second or so.
At screwcutting speeds the torque is already low so just droops away.
To me it would seem to tie in with the slow ramp up response (ie it is struggling at low speeds) I am guessing it needs quite a boost to get up to speed from zero quickly . Just doesn't seem to be getting that.
And I guess it needs a quick boost to hold speed on threading . Just isnt getting it .
boxford tcl125 problem!
By glinner81 in forum Boxford LathesReplies: 3Last Post: 27-05-2021, 06:36 PM -
Boxford 165 HMC - Spindle motor identification
By PaulColeman in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 24-04-2021, 08:19 AM -
CONVERSION: Emco F1-p Mill Mach3 convention, Spindle motor problem
By andre13442 in forum Conversion Build LogsReplies: 7Last Post: 14-01-2016, 12:14 PM -
Boxford VMC 300 Sirel Spindle Drive and motor
By Joe in forum Boxford Vertical MillsReplies: 0Last Post: 12-08-2015, 07:46 PM -
Boxford 125 TCL Searching for machine problem
By dragon in forum Boxford LathesReplies: 1Last Post: 28-12-2014, 09:27 PM
