Hi. When I set the axis to 20mm it moved 20mm. Last test. Checked x and y axis moved correctly to measurements input which they did. However had to stop test as a red led came on for the z axis. This is the 6th time this led as lid up and I have checked all the wiring so think it maybe a fault in the unit. So before I go ahead wasting more time, what’s the best place to buy good Quality stepper drivers in the uk. I did use zapp automation but that’s gone now. Thanks.
24-08-2021 #2
I have only ever seen UK sellers reselling drivers made in China, at least for the hobby market. So you are paying a premium for after sales support and easy return if you buy from here.
ArcEuro used to sell them but I think they don’t anymore. CNC4YOU (?) I think still do.
For the red LED have a read here
http://www.mycncuk.com/threads/3899-Driver-Lights-Red
Switch off the drive and they should spin freely. If not the coils are shorted out due to incorrect wiring. Check which coils you have joined together depending on if you intend them to be parallel or series wired.
Usually if the wires are shorted the driver will pop. At least the older analogue ones did.
If it is intermittent then the coils are wired ok and as you say the drive could be faulty, or in theory the stepper itself could be faulty. You could try swapping drivers over and see if the fault stays with the driver or with the motor.
Another option is to power it up without the motor and step dir connected and let it warm up and sit there. Maybe something is not right and is getting hot because it is faulty.
24-08-2021 #3
Yes, that’s what I have found out, it,s amazing the price difference between sellers for the same item. I think that the z axis motor is failing, so have ordered a new one along with the drivers. I would of liked to go closed loop, but the cs-labs controller can play up at times using a closed loop system. The new parts should turn up this week, so will play around over the weekend. With luck it should work out ok.
24-08-2021 #4
Who's told you that load of rubbish.?
The Cslabs controller knows nothing about what drives it controls, that goes for closed-loop stepper drives or Servo drives. All it does is send out pulses to the drives after that it knows nothing about the position or even whether the pulses were received.
The closed-loop portion of the stepper system is solely kept between the drive and the motor and nothing gets fed back to the CSlabs controller, the only part it plays is producing the pulses and to that end, it doesn't know or care what receives them.
I have built dozens of machines with Cslab controllers and closed-loop steppers and I can tell you with 100% certainty that it works perfectly fine with them.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
24-08-2021 #5
Hi jazz, I fitted a closed loop motor and driver to my last machine, and it did not like it. It may of been that I only used it on one axis. But it could of been me. However I have read on a few forums that people have had a few problems. I think if ever I get this mill working as it should I will fit closed loop on all axis.
25-08-2021 #6
Hi Terry, I can assure you 100% that the Cslabs or any other open-loop Step/Dir controller for that matter knows nothing about the drive which is attached, they just send out pulses and trust the drive receives them. Now, you can get drives that handle pulses timings differently but I've yet to see a Closed-loop drive or any drive for that matter that doesn't work with the Cslabs controller. However, pulse timing issues can usually be dealt with in the control software motor tuning.
NEW MEMBER: You need a CNC to make a CNC.
By quadrilateral in forum New Member IntroductionsReplies: 4Last Post: 25-04-2017, 08:13 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM -
How would you make these, or something near enough...
By irving2008 in forum General DiscussionReplies: 8Last Post: 22-09-2012, 09:36 PM -
Using Games Contoller with Mach3
By cropwell in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 01-08-2012, 12:13 PM -
How to make something like this?
By lateAtNight in forum Machine DiscussionReplies: 2Last Post: 13-05-2009, 08:16 AM
