Thread: enable pins on stepper driver
I haven’t used enable but I’m pretty sure it works something like you described. But wait for a second opinion. My main concern is if you rotate the motors they will send power into the drivers which they might not like. I think it would need a mechanical clutch as well.
Is it the Clough42 ELS system by the way ?
26-08-2021 #2
I am using a simple program from Dronebot workshop that just allows me to change direction and speed. I have a tachometer on the machine so in the future i may try and write a program that ties the stepper to the spindle speed. I think if i was going for full control i might go for Jon Bryan's program. It looks simpler.
Dan
Wiring an enable / disable switch for each driver
By mbridge87 in forum General ElectronicsReplies: 11Last Post: 09-11-2021, 11:36 PM -
Enable pins on Stepper driver, are they required?
By ROBCNCAU in forum Motor Drivers & ControllersReplies: 31Last Post: 30-10-2019, 10:03 PM -
WANTED: Conqueror Design stepper driver or stepper conversion board
By pistolknight in forum Items WantedReplies: 1Last Post: 25-05-2019, 11:57 AM -
How to wire the enable pin on a stepper drive?
By cncJim in forum General ElectronicsReplies: 8Last Post: 01-01-2016, 05:10 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM
