10-12-2009 #8
Irving, that's a most useful post - I'm going to bookmark those calculations for future use..., thankyou.
I recon Irving's hit the nail on the head withThe meaning of mid-level could be very different depending on who you're talking to. Although both of these chaps has built/converted a machine to run with EMC2, you'd probably get a different answer about "mid-level" from each... :)The question I suppose is...
[ame="http://www.youtube.com/watch?v=LA5qCIB0j6k"]YouTube- Fresa CNC MDF[/ame]
[ame="http://www.youtube.com/watch?v=mxxdq6y8z8M"]YouTube- EMC2 5 axis cinci at MPM[/ame]
So how about a list of variables, so that we can discuss pros and cons?
(low-spec -> high-spec):
* Working size (min A4 -> max 4ft x 8ft flat sheet)(Z depth?)
* Linear bearings (unsupported rails -> skate bearings -> v bearings -> supported round rails -> recirculating ball carriages)
* Drive method (chain/allthread -> belt/trap screw -> ballscrew)
* Target cutting speed vs. target resolution (trade-off)
* Rigidity & strength (just cut alu, or rip through it in a breeze?)
* Spindle type and power (dremel -> 43mm router -> handheld router -> VFD spindle)
Probably loads i've missed, so copy paste and add/change bits...
On my wishlist would be the ability to add a 4th axis (parallel with x) at some future time, without hacking the machine to bits. Designed in expansion capability if you will...
Anyone have a UK source for open ended 10mm T5 Polyurethane belt
By cweeks in forum Linear & Rotary MotionReplies: 18Last Post: 19-03-2016, 09:43 AM -
Open Source Dust Shoe Designs
By Tomnewry in forum Open Source Designs & PlansReplies: 22Last Post: 30-06-2014, 01:51 PM -
Open Source Servos
By D.C. in forum Open Source Designs & PlansReplies: 0Last Post: 07-03-2013, 07:29 PM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
SHAPEOKO, the open source CNC
By baz550 in forum Open Source Designs & PlansReplies: 6Last Post: 31-05-2012, 08:59 PM
