29-08-2021 #9
That's because it's not designed to do that so why they are trying is beyond me, don't they think if it could then CncDrive would promote that it as 5 or 6 Axis onboard.? Only port 3 provides the extra I/O needed and they clearly state that only 8 pins are wired for Step/Dir on the board in the manual.
To me, the AXBB-E is perfect if you have a machine that only requires the standard I/O it offers but with the added bonus that if at a future time you need a little more then you have the option to add-on.
If you know you need lots of I/O from the start then go with the UC300 + BOB option.
Also, another plus for the UB1 which can't believe I forgot mention was the fact it offers differential outputs which can be a BIG deal for some setups, esp if using Servos.!-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
New UC300ETH Breakout Board/Motherboard
By Ger21 in forum CNCdrive (UC100, UC300ETH)Replies: 10Last Post: 17-07-2019, 09:41 PM -
anyone using an e-cut 1 mhz usb breakout board
By nobby in forum Control Hardware & SystemsReplies: 10Last Post: 22-10-2018, 11:50 PM -
which breakout board?
By johngoodrich in forum General ElectronicsReplies: 4Last Post: 12-03-2017, 01:54 AM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
