Thank you Dean, that was very helpful.
Ah yes, good to know !
I did look at the AXBB briefly but didn't go into the detail. Looks interesting. I need 5 axis control (2X, 1Y, 2Z) and this offers 4 by default. It says another 2 can use configurable I/O pins to make 6 in total. I'm trying to work out if I lose too much by doing this and am going through the manual.
Aside from the steppers the other inputs/outputs on my CNC machine are:
2off prox for homing X axis both sides
1off prox for homing Y axis
1off prox for homing Z axis
1off limit prox on X axis
1off limit prox on Y axis
(no limits on Z)
2 estop switches
Probe input
Pendant controller, but I don't really use it so not a big deal if it can't be used
In/out not required:
I have a direct manual start/stop switch and pot for the VFD control mounted on the main cabinet panel, direct to the VFD. I don't really go for software/BoB control for these but that is my personal choice and so is not really needed on the BoB.
Also no plan for ATC any time soon so that is not required for I/O
AXBB-E also appears to have an additional connector for something like the UCSB to give more in/out, but I would like to see if the above requirements can be met without it.
OK, good to know. I need to check the above, then will email for all in price. Thanks
New UC300ETH Breakout Board/Motherboard
By Ger21 in forum CNCdrive (UC100, UC300ETH)Replies: 10Last Post: 17-07-2019, 09:41 PM -
anyone using an e-cut 1 mhz usb breakout board
By nobby in forum Control Hardware & SystemsReplies: 10Last Post: 22-10-2018, 11:50 PM -
which breakout board?
By johngoodrich in forum General ElectronicsReplies: 4Last Post: 12-03-2017, 01:54 AM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
