30-08-2021 #21
I don't know if this is just an academic quibble, but is there an issue with the concept of two steppers driving a single, very rigid, axis with no possibility of adjusting their relative position? I'm thinking that the typical micro-stepping driver (although possibly not the latest and greatest) will reset to the nearest full step at switch-on, and there is no reason to suppose that the "full-step" positions on both steppers will align. In the case of the typical both-ends-of-a-gantry setup, there is enough give to allow for this (and we are taking about quite small mis-alignments - a full step with a 5mm pitch screw is only 0.025mm) but auto-squaring takes this out anyway. But if this dual-drive Z axis is going to be much stiffer, is this an issue? Maybe this will be addressed at initial setup?
I believe that some newer stepper drivers will maintain micro-step position across switch off/on, which might help.
New UC300ETH Breakout Board/Motherboard
By Ger21 in forum CNCdrive (UC100, UC300ETH)Replies: 10Last Post: 17-07-2019, 09:41 PM -
anyone using an e-cut 1 mhz usb breakout board
By nobby in forum Control Hardware & SystemsReplies: 10Last Post: 22-10-2018, 11:50 PM -
which breakout board?
By johngoodrich in forum General ElectronicsReplies: 4Last Post: 12-03-2017, 01:54 AM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
