Thread: Limit switch problem
Basically the principle of this image below is the same for everything.
You connect your relay to your control for operation of on/off coil.
You split 1 of the power lines between the pump and it's plug and fit the relay ouputs inbetween there.
In the case of the image the positive line has been split and connected to the relay COM & NO.
With a SSR it would just go to the 2 output contacts.
Active low/Active high will be used to set relay as closed whilst machine on or closed when off depending on when you want the pump to operate.
This is 12v system for arduino. Instead of 12v you would just be using your 250v. Wiring is the same regardless.Last edited by dazp1976; 02-09-2021 at 10:40 AM.
Inductive Limit Switch problem
By Kitwn in forum Control Hardware & SystemsReplies: 86Last Post: 29-04-2020, 12:51 AM -
Limit switch problems
By Neeps in forum General ElectronicsReplies: 9Last Post: 11-09-2016, 12:02 AM -
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM
