Page 2 of 2 FirstFirst 12
    I've seen many lathe videos using a flood coolant stream from aquarium pumps, but not mist.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 14 Hours Ago Has been a member for 8-9 years. Has a total post count of 485. Received thanks 81 times, giving thanks to others 26 times.
    I used a central heating pump on my Bridgeport. They do a fine flow rate and also a big static head. The main downside is that they don't self prime but if you mount the pump below the reservoir surface, this isn't a problem. Pretty quiet and don't even mind being stalled long term if you turn the tap right off.
  1. How much airflow needed for mist cooling setup???
    By Voicecoil in forum Swarf & Chip Management
    Last Post: 25-01-2020, 06:46 PM
  2. Replies: 2
    Last Post: 21-04-2016, 09:18 AM
  3. Boxford 160TCL to Mach3
    By Jones_Rob in forum Boxford Lathes
    Last Post: 21-10-2015, 01:17 PM
