As said. 5VO from power out (next to 24v power in) then the rest according to JAZZ.
This will likely give you 0-5v speed output if the board is in stock form.
If you need it to be 0-10v for speed control instead:
In the manual.
Pages 21 & 27.
There is apparently a jumper on the board marked J1.
This changes the voltage range between 0-5v or 0-10v depending on the jumper position.
Looks like you have to take the case off the AXBB-E and change it.
There are some drives out there that still only run 0-5v analog, so this controller is built to accomodate these as well as the newer 0-10v drives.
(Increases saleability for the older boys I guess).Last edited by dazp1976; 02-09-2021 at 12:13 AM.
AXBB-E any opinions?
By ngwagwa in forum Motor Drivers & ControllersReplies: 12Last Post: 21-07-2021, 04:32 PM -
moving from Mach3 to AXBB
By ngwagwa in forum CNCdrive (UC100, UC300ETH)Replies: 5Last Post: 12-04-2020, 10:01 AM -
looking for a pendant to work with Cslabs ip-m mach 3
By charlieuk in forum CS-Lab (CSMIO)Replies: 7Last Post: 22-09-2017, 03:56 PM -
Cheap CNC breakout board for controlling spindle speed, will this work?
By ROBCNCAU in forum Spindles & Drive MotorsReplies: 7Last Post: 04-08-2016, 02:48 PM -
Mach lathe spindle speed control
By GeoffV in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 21-05-2014, 08:34 AM
