If you disconnect the wires from A01 and 5V0, then measure the output between those terminals on the AXBB unit with a volt meter what happens? Typing different S values into the MDI window such as S500 S10000 S24000 should show different voltages which relate to the speed requested. If this is not working it must be the software configuration?
I think this needs to be right first then you know that is working and you just need to connect to the VFD.
AXBB-E any opinions?
By ngwagwa in forum Motor Drivers & ControllersReplies: 12Last Post: 21-07-2021, 04:32 PM -
moving from Mach3 to AXBB
By ngwagwa in forum CNCdrive (UC100, UC300ETH)Replies: 5Last Post: 12-04-2020, 10:01 AM -
looking for a pendant to work with Cslabs ip-m mach 3
By charlieuk in forum CS-Lab (CSMIO)Replies: 7Last Post: 22-09-2017, 03:56 PM -
Cheap CNC breakout board for controlling spindle speed, will this work?
By ROBCNCAU in forum Spindles & Drive MotorsReplies: 7Last Post: 04-08-2016, 02:48 PM -
Mach lathe spindle speed control
By GeoffV in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 21-05-2014, 08:34 AM
