Thread: 3000x1500mm table drawing stage
Yes, the frame needs to be braced and welded completely if being machined but that's true anyway for a good machine whether machined or not. If done properly then transporting should make no difference.
Epoxy is ok but at this size, it's not cheap and it's very easy to get wrong. Also, while the epoxy method is much better than no prep of the surfaces it's still only an intermediate level of accuracy and again at this size very easy to get wrong (can you see a theme here.?)
Having the frame machined isn't as expensive as you might think, but yes it's not £150-£200 like epoxy but it's also not thousands as you might imagine it to do be.!
To be honest, I was just about to hit the button on buying/building a large machine for surfacing frames but our landlord recently sold the industrial estate so we may need to move premises so I'm holding off until it's decided as it won't be an easy or cheap machine to move, plus we have a large Hurco mill that weighs 9 ton and other smaller mills/equipment which will take some shifting. However, when we do then I will be building and offering the machining service and steel frames for sale.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
Next stage is Plasma add on...
By Skiprat in forum Plasma Table MachinesReplies: 20Last Post: 05-04-2017, 11:31 PM -
eBay: NEAT XY-1010 xy table 8" travel very solid 17kg table NEW ebay.co.uk 251715555999
By emlclcy in forum Items On eBay UKReplies: 0Last Post: 12-11-2014, 09:14 AM -
BUILD LOG: Design stage of 4030(ish) for wood and plastic
By andy586 in forum DIY Router Build LogsReplies: 4Last Post: 14-11-2013, 10:07 PM -
Small Mill very early design stage
By leadinglights in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 15-06-2010, 01:05 AM
